It is currently Fri Jun 19, 2026 5:18 pm
PostPosted: Tue Aug 18, 2015 11:18 am
Hello,
My main halyard snapped on me :(
Not sure how to install a new one, should I remove the top cap? is there an easy way to run the new halyard though the mast.
I have searched on the web and all I can find is replacement of a current old halyard but not installing one.
Thank you in advance for your time,
Gilbert
PostPosted: Tue Aug 18, 2015 11:49 am
You can run the line through the top pulley pretty easily - it may take a little twisting/luck though. I was able to do it while getting eaten alive by horseflies a few weeks back. Once you run it down to the bottom of the mast you can remove that pulley and run it through.
Hope this helps.
/It may work differently on a comp-tip mast
Justin
H18 Magnum
Contour 30MKII Trimaran
PostPosted: Tue Aug 18, 2015 12:16 pm
Push up though the pulley and into the luff track... start top. Using a spike or long nail, poke / hook the line through the track opening and drag down the length of the mast. Pass through the lower pulley.
PostPosted: Tue Aug 18, 2015 5:04 pm
thanks for your quick answers,
Gilbert 8)
