It is currently Fri Jun 19, 2026 1:47 am
Post new topic Reply to topic  [ 51 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Mon May 18, 2015 12:12 am
I must say that as someone who has sailed a 2008 AI for years with never having to deal with such a thing that I now await my new 2015 AI with some slight concern.
Takes the shine off a new boat a bit.
Fair Skies, Max.
PostPosted: Mon May 18, 2015 12:51 am
Not a problem. Add a Sprayskirt and simple leashes to the rear, to be sure the aka stay in and you're set to go.
The shear-bolts are not a major difference from our old boats. So, if you haven't broken one and rolled your current AI, I don't see a reason the new one should be a worry.
Then again, maybe you'll be hot-dogging more it in your new 'ride'. Is that something not to look forward to? :lol:
PostPosted: Mon May 18, 2015 1:01 am
By the by... does anyone know the diameter of the shear bolts?. I'm guessing 1/4"??
Never mind!!!!!... found it :mrgreen:
Follow my blog @ Saltwater Kayak Fisherman
Watch my videos on You Tube
Team Hobie GB
Lowrance Pro Staff
YakAttack Pro Staff
Hook1 Crew
PostPosted: Mon May 18, 2015 2:26 am
OK.
Spray Skirts still needed eh, I was told the 2015 AI was a drier ride?
Fair Skies, Max.
PostPosted: Mon May 18, 2015 2:51 am
I have a 2015, though I've not used an ealier model. That said, I've already caught a few in the face :D
Team Hobie GB
Lowrance Pro Staff
YakAttack Pro Staff
Hook1 Crew
PostPosted: Mon May 18, 2015 3:03 am
Lol I guess it's subjective, here where we have Parrots and Palm Trees a face-full can be refreshing, if you are expecting it..
On that subject, any tips for good suppliers of spray nets?
Fair Skies, Max.
PostPosted: Mon May 18, 2015 6:23 am
The attention here has been on the nylon sheer bolt but I saw my buddy yesterday who had a TI capsize and confirmed with him that it was the "knob" attached to the hull that had worked loose when his ama collapsed. I checked mine on a 2015 TI and both of the knobs had some loktite already and I put them back in with a good coating of loktite blue. My friend says he checks the knobs all the time to make sure they are always tight. My opinion.. that knob is more of where you should be concerned..
I also just sailed the crap out of my 2010 AI, never had the slightest issue.. I’m being a little more paranoid with the TI because now I will have my wife on board and want to take it up to the Puget Sound in Sept (cold water).
Spray skirt - look at the link at the bottomn of Kayakingbobs post
PostPosted: Mon May 18, 2015 1:49 pm
My new AI is still in the container so I have not actually scoped one yet.
Appreciate Knob advice and Bob link.
Fair Skies, Max.
PostPosted: Tue May 19, 2015 5:15 am
Bob and company,
Great info here for a new one like me! I can just share some tales from my T-Gull experience: Gulls have turnbuckles holding the water stays to the boat; the stays prevent the akas/amas from swinging back against the hull. After a few frightening tales that I only read about, thank goodness; the turnbuckles came wired from the factory! Stainless pins are removed to allow the akas/amas to swing back against the hull when pulling Gulls out of the water; Corsair and Farrier tris use very different hardware for mounting their akas and amas and do not have this potential problem. Thanks for the heads up; I plan on putting Bob's plan in place as soon as my new TI arrives.
Rob
PostPosted: Mon Jun 08, 2015 8:40 am
Just a reminder to check those "knob" screws. My wife's came loose on her 2012/3 AI this weekend. She didn't capsize thank goodness. I checked and her other knob screw needed about 1/4 turn to tighten.
PostPosted: Mon Aug 31, 2015 5:21 pm
tonystott wrote:
This is precisely why I modify my shear bolts by elongating the hole in them to fit a 2mm zip-tie. Hugely easier to fit with wet fingers while away from shore, and absolutely zero need to replace it with a nut and bolt later. The zip-tie is threaded through itself to make a secure self-locking loop.
I would recommed that you modify ALL shear bolts to ensure there is a vertically elongated slot filed in them to tske a zip-tie. In my opinion, those split rings are the work of the devil :twisted: .
This one made it to my list of required mods.
Now I am thinking about what/how can I bond to the head of each replacement bolt so that it will float when dropped. Shouldn't take much....a little piece of pool noodle...anything that displaces enough water to float the bolt.
Only question is what the best adhesive is.
I just bought some Gorilla construction adhesive for the on-beach storage stand I am making...so I guess I will try that first.
2017 Trailex 450 Trailer
Pre-September 2015 cradles
eMail: [email protected]
PostPosted: Mon Aug 31, 2015 9:03 pm
Seriously, just how clumsy are you? I am a diabetic, and my fingers are partly numb, but even I would have no problem getting a new bolt into the brace. Sliding a zip tie into the slotted end afterwards would be a bit fiddly, but unlikely to cause the loss of the new bolt.
I like that you are trying to cover all possibilities, but it is easy to overthink it. I certasinly wouldn't bother trying to add buoyancy to the shear bolts...
PostPosted: Tue Sep 01, 2015 4:20 am
Have you actually done it - in 3' chop with cold hands?
I would say that the odds are against me doing it successfully under real conditions - and I think of how PO'd I would be to see that little thing sinking out of sight....
PostPosted: Tue Sep 01, 2015 4:35 am
I don't think you understand at all. To replace a shear bolt, you COLLAPSE the ama, so you are working up close, not trying to do the job out away from your seat. If the sail is furled, conditions would have to be truly diabolical to make fitting a new sheer bolt too difficult.
Now if you were talking about a rudder bolt....
PostPosted: Tue Sep 01, 2015 5:13 am
Sounds like, right now, I am too much talk and not enough experience.
But what got me going was reading multiple reports by people who seem to be shearing bolts on a fairly regular basis.... one person reported a shear each time the lee ama was completely submerged - so I figured I would want something really foolproof...
FWIW I am pretty sure that, on dry land, I could replace that bolt with my eyes closed using only my teeth..... but my experience has been that on the water things are different. I guess I will find out soon enough.
The rudder pin? I'm not even considering replacement. Had a difficult time doing it on dry land.... Once I get this thing in the water, one of the first things I plan to do is learn to steer it using a paddle as a steering paddle or steering oar.
