It is currently Mon Aug 03, 2026 12:43 am
PostPosted: Wed Sep 16, 2015 7:40 pm
After capsizing my 16 for the first time last week and pulling it up on the trailer afterwards I discovered I had a pretty serious leak in the hull. Previous outings I had a small amount of water in the hull, but after the capsize I had well over a gallon in the port hull, starboard was bone dry. I followed the instructions from the post by Matt Miller and put a small amount air pressure in the hull from my shop-vac and the leak-point was made instantly apparent.
Inside the hole where the shroud attaches to the hull it appears there is a hole through to the inside of the hull. There is no evidence of trauma to the area or excessive force. It almost seems like it was present from the time the hole was drilled but I can't imagine the previous owners living with it? (or maybe they did?) Either way I need to remedy the problem. I would appreciate any feedback or suggestions, but I'll outline my plan of attack below.
My plan (feel free to make suggestions)
- Inspect the hole further and make sure the surrounding area isn't too soft or rotten.
- If necessary use a die-grinder to clean the area up, taking care not to enlarge the hole any more than necessary.
- Apply a very very very slight vacuum to the hull (with shop vac or possibly a vacuum tester I have for automotive use.) This will help pull the fill material into the hole.
- Fill hole using either fiberglass resin mixed with some finely chopped fibers, or Marine Tex
-Let dry sufficiently
-Chase shroud anchor hole with drill to clean out any excess material left from repair
Any insight or suggestions to the plan would be appreciated. I've attached a picture of the hole. The picture is looking up from the bottom of the hull to the underside of the lip/hole.
PostPosted: Thu Sep 17, 2015 5:27 am
I would use thickened epoxy or Marine-tex there since you won't ever need to gel coat that area. Otherwise, your approach sounds good to me.
If after it cures you find via another leak test that it did not seal, you could tape off the bottom of the hole and fill it with epoxy and then re-drill it.
Jim
PostPosted: Thu Sep 17, 2015 6:09 am
Jim
Thanks Jim. My initial thought actually was to do just that, fill the hole and re-drill but I was afraid of not having proper alignment with no guide or pilot hole to follow. Definitely a good backup plan though.
PostPosted: Thu Sep 17, 2015 8:22 am
This was something I have seen before. The glue bead inside the hull is small or there is an air pocket. Easy to fix with resins or sealants... or both.
PostPosted: Thu Sep 17, 2015 8:42 am
Thanks Matt. Just pack some resin in there and call it a day?
PostPosted: Thu Sep 17, 2015 8:43 am
Followed by some sealant upon pin install and for sure!
PostPosted: Thu Sep 17, 2015 8:51 am
Cool. Do you have a recommended sealant or just some uv-resistant silicone like for doors/windows like you can get at the hardware store?
PostPosted: Thu Sep 17, 2015 9:27 am
Perfect. Will be inside the hole and covered by the pin.
