It is currently Thu Sep 18, 2025 9:37 pm
Post new topic Reply to topic  [ 62 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: Design Flaw
PostPosted: Thu Dec 17, 2015 6:05 am
I can, yes. And until and unless you try it, you can't say what it will or won't do.
But once again, nobody is forced to try the horn cleat if they don't believe it's going to be something they'll like. I put it out there for those that might want to try that option over the factory supplied camcleat. That's all.
PostPosted: Thu Dec 17, 2015 8:48 am
mmiller wrote:
On cats we trap as far aft as possible in higher winds. You pop the bows up and use the rudder as lateral resistance. Once speed is up, you can retract the dagger board a bit as well. You don't need all of the surface area if at speed and it can cause the boat to trip (tip) which slows you down too.
There is no one seat best for all points and wind speeds.
Matt, do you pull daggers up when heading up as well as running? If so, would that work on a TI or would the hull shape cause the boat to slide too much?
Thanks.
PostPosted: Thu Dec 17, 2015 8:57 am
...I put it out there for those that might want to try that option over the factory supplied cam cleat. That's all.
Some people are very good at visualizing things, even if they have never tried them. All of us know and have used open (horn) cleats.
Tom, I think the problem that some of us are having with the open cleat option is, why try it if we are happy with the cam cleat set up? You sparked the discussion with your statement:
Tom Kirkman wrote:
...Same with the mainsheet. Unless the wind is very, very light, it should be in your hand most of the time. For that reason I removed the cleat entirely - it's not needed.
...All the stuff about "angles" and "distance from cockpit to cleat" goes out the window with the horn cleat next to your seat. It's really worth a try. I certainly won't go back.
And, I don't agree with your statement, "Unless the wind is very, very light, it should be in your hand most of the time." Even the day I capsized, I had no time to release anything. I was over in an instant--didn't even see it coming. I didn't believe it in that first and only instant. Suddenly, the aka/ama was within a foot of the hull. Out of the corner of my eye, I could see the windward aka/ama/haka up high overhead. My insta-thought, "I'm going over." I did. I went over so hard, the end of the mast and sail pocket gauged mud out of the bottom (6-7' deep) as it bounced off the bottom. It was not a "slow" capsize.
That was my first capsize in 8 yrs of Island sailing. It was in strong winds, rough chop, with a broken shear pin--insta-capsize, as Yakass says. Personally, I'm not going to hold a line in my hand hoping to avoid a capsize in the next 8 yrs. I am going to deploy "keep-out" lines, always.
PostPosted: Thu Dec 17, 2015 9:09 am
I was under the impression from this thread that some are not happy with the supplied camcleat set-up. So I offered an alternative. That's all. Hopefully some of those who aren't happy with their camcleat will give my idea a try. I suspect some will find it superior, while others who try it may not.
PostPosted: Thu Dec 17, 2015 9:13 am
On cats and windsurfers... daggers can be partially retracted when sailing upwind... when the wind is up. I would think the Islands are similar, but not being as fast through the water this may not be as effective as it is on a catamaran. Absolutely when not pointing high into the wind you can do this. Something to try I think.
PostPosted: Thu Dec 17, 2015 1:20 pm
I wonder if this is why my boat always feels faster on a starboard tack versus port tack - since, when on a starboard tack, there is less dagger board in the water due to heeling and the dagger board being mounted on the starboard side. I think I'll play with the dagger board a bit the next time I'm out. I usually just put it all the way down and forget about it.
-- Chad | 2014 TI
PostPosted: Thu Dec 17, 2015 8:07 pm
All good food for thought.
PostPosted: Fri Dec 18, 2015 7:37 am
I was looking at a video I posted a year ago. It was the start of a camping trip, winds were about 25 mph, gusting to 30. As I emerged from the protection of the shore trees and began to feel the brunt of the winds, you can see that I was uncomfortable and had the main line in my hand at the ready. As things went south, I did release the cleated main sheet at 54-55 sec into the video, although it happens so fast you may miss it. In the repeat, slo-mo version, I can be seen releasing the main sheet at 1:42 min. I was using my 2011 AI. Here is the 2 minute video.
When I capsized in my AI 2 last April, I was not feeling threatened. It was just a nice, windy day sailing. I was taking a video shortly before the disaster. No problems...until the insta-capsize.
PostPosted: Fri Dec 18, 2015 2:16 pm
Thanks! I've pulled boards up when running but never played with them on other points on the mono hulls that I've sailed. That old habit carried over to our TI so the fresh point of view is appreciated.
PostPosted: Wed Dec 30, 2015 7:35 am
fusioneng wrote:
Keith:
Where did you get that from (Hobie recommends solo in the rear), I know of nothing more awkward, can't reach the centerboard, can't reach the furler, your head gets chopped off by the sail control lines, there is no way possible to hike out ever. And the bow is so high the boat gets blown off course all the time. I think the opposite is true the boat was pretty much designed to be soloed from the front where in my opinion the boat is much better balanced and you can reach everything easily, you can hike out on the tramps and you don't get your head taken off by the sail control lines. All just my opinion of course, but if I had to solo from the back I would have got rid of the boat a long time ago (I feel totally trapped back there. You have no means to balance the boat to keep the AMA's out of the water))
Your kidding right ?
FE
I was browsing my 2014 Hobie Mirage Tandem Island Owners Manual and, on p17, 3:1 Mainsheet Conversion, and found: "Most solo operation of the boat is from the back seat, ...."
Maybe my friends weren't leading me astray! Of course, I never intend to solo my tandem (I have an AI 2 for solo sailing), so I will always have a partner in the front seat to handle the centerboard, the furling line, and tiller when needed. Depending on the front seat person, they may even hike out on the hakas to keep us level and moving faster. All sounds good to me. Nancy and I did our first sail 2 days ago. A 14 mile run in Biscayne Bay.
PostPosted: Wed Dec 30, 2015 11:44 am
I believe there is a miniimum weight of the solo TI sailor that makes sailing from the rear seat a real negative when exceeded. I don't know what is the magic number, but can assure folks that it is less than 300#. I sit in the front seat, which happens to spread my heft close to evenly front and back. Sure I get more nose-burying, but I can minimise this by loading heavier stuff down back.
PostPosted: Wed Dec 30, 2015 12:06 pm
I can assure you it's less than 230#.
"Third Normal Form"
  • Trampolines
  • Hobie cover
  • Davis Spar Fly
  • Kayakbob's Sprayskirts
  • Spine Board Hakas
PostPosted: Wed Dec 30, 2015 2:25 pm
I suspect my situation is different than most peoples specifically because I have never sailed my TI without a jib sail which probably completely changes the handling characteristics of the boat. The angled foresail creates quite a bit of lift to the bow, with the foresail the tip of my bow is normally 3-4 inches out of the water when I'm in the front seat, when in the back seat solo the bow is about a foot free and clear of the water. The foot of my jib is mounted about a foot ahead of the bow cleat on my bowsprit. The side force created by the jib when sitting solo in the rear makes steering near impossible. When sailing tandem the boat is perfectly balanced and can be sailed from either position easily. I have also never had my TI out without at least 1 outboard mounted to the boat for safety reasons. I assume all these things factor in though I fail to see any difference in the boats handling with a 20-25 lb outboard hanging off the back tilted up. Actually even with twin 25 lb (ea) outboards tilted up I can't detect any changes to the sailing characteristics of my TI. Actually having a little extra weight in the rear appears to improve things a little (for me anyway).
Everyone has a different situation, I have my setup rigged and tuned to solo from the front seat, it works for me thats all that matters to me.
FE
PostPosted: Sun Jan 03, 2016 4:45 pm
With regards to the cleat and sheet, has anyone moved it to the left side. I have some tendonitis in my right hand.
2007 AI - starting to fall apart :)
PostPosted: Mon Jan 04, 2016 2:30 am
Tom Kirkman wrote:
No, with a horn cleat you don't have to manage it 100% of the time. You can either leave it uncleated, half cleated or full cleated, which you can't do with the supplied clamcleat where you're either cleated or uncleated. The horn cleat just gives you a 3rd option and a better means of handling the sheet in a wider variety of conditions.
I do a LOT of sailing on a LOT of different boats. The #1 reason for most sailing capsizes among those I sail with is - keeping the mainsheet cleated in an auto-camcleat like the one on the Island.
Not trying to force anyone around to my way of doing things, but for the Islands, the horn cleat next to the seat is worth a serious look. I hope anyone that tries it will report back here with how they liked it, or didn't.
Dear Tom,
last time I was out with my Ai I tried your suggestion.
I just passed the mainsheet line under the aka and I was really surprised how easily I was able to manage the line.
So I would be going to follow your mod.
I already installed a passtrough ring under the aka, and I am going to install an horn cleat,
But I was also thinking that instead of use an horn cleat it could be better to use a zig-zag cleat.
Have you never consider such an option?
Biagio
