It is currently Tue Aug 04, 2026 1:01 pm
 Post subject: Pedal drive alignment
PostPosted: Mon Jan 15, 2007 9:05 am
Just got my 2 new Revos the other day , but havn't had them out in the water yet. I noticed that with 1 of the drives when you line the blades up together they are not verticle, but lean to one side. If you line the front one up verticle then the back one is WAY off and vise-versa. Is there a way to adjust the alignment so that they are straight? The other drive looks OK and is straight like it should be.
 Post subject: Alignment
PostPosted: Mon Jan 15, 2007 10:27 am
Chain / cables can be adjusted to center the fins.
PostPosted: Mon Jan 15, 2007 11:00 am
Thanks Matt. I'm a dummy so is there a proper way to do the adjustment or do I just loosen/tighten the nut on the drive or what?
PostPosted: Mon Jan 15, 2007 12:06 pm
Thanks again Matt. I figured it out. everythings cool and can't wait to get on the water.
