It is currently Mon Aug 03, 2026 3:47 am
 Post subject: rivets
PostPosted: Fri Feb 05, 2016 12:07 am
Dear Mr Miller would you be so kind to help me with complete list for rivets related to corners, front and rear crossbars with correct material for them (alu or s.steel)
I will pass your list straight to a dealer
advanced thanks
Massimo
 Post subject: Re: rivets
PostPosted: Fri Feb 05, 2016 5:47 am
Check the parts manual for the 16. http://www.hobiecat.com/support/hobie-16/ That should have a rivet guide for your boat.
PostPosted: Fri Feb 05, 2016 12:16 pm
Thank you but I'd been looking at it before post the inquiry but wasn't that clear to me , may be I missed something . I will double check. Thanks
PostPosted: Fri Feb 05, 2016 2:21 pm
From the parts guides...
Front Crossbar
Corner Casting 8011231 (6)
Rear Crossbar
Stainless steel. Part numbers indicate length:
8011231 RIVET POP 3/16 x 1/2 PH (Pan Head)
Total of 12 per boat.
PostPosted: Sat Feb 06, 2016 1:11 am
Thank you Mr Miller i' ve found it in the us version parts guide , bat cause i'm from italy i've wached at the euro version and i donn't see any rivets list in it and the corner cast rivet code 99210003 ( only this mention to rivets at page 6 of the whole guide ) is indicated in aluminium , but i will follow your indication with s.steel
