It is currently Mon Aug 03, 2026 2:13 pm
PostPosted: Thu Feb 18, 2016 3:50 pm
When you trailer your AI, do you remove the seat and carry it separately ?
Somewhere I think I read an admonition to always remove it - but I can't figure out why, given that it can be folded down and held in place by the rear hull tiedown strap...
2017 Trailex 450 Trailer
Pre-September 2015 cradles
eMail: [email protected]
PostPosted: Thu Feb 18, 2016 6:46 pm
I car top mine but always with the seat in but held down using the mirage drive bungee. No problems in 3 years so far.
Greg
2016 AI - Spinn & Jib
– Charles G. Davis
PostPosted: Thu Feb 18, 2016 7:01 pm
I've always removed my TI's seats while trailering. Just worried about losing them.
"Third Normal Form"
  • Trampolines
  • Hobie cover
  • Davis Spar Fly
  • Kayakbob's Sprayskirts
  • Spine Board Hakas
PostPosted: Thu Feb 18, 2016 7:30 pm
I was told by two different dealers (one for the outback and a different one for the TI) to remove them. I do not, I use the mirage bungee to hold them down and have yet to have any trouble or see so much as a wiggle out of the seat...
if I cartopped I might remove them for the piece of mind (since you cant see them) but on my trailer I can see both seats while going down the road...
2015 Outback- dune with sail kit
2015 TI- dune- sold
2015 AI2- Hibiscus- should probably sell...
2018 AI2- Dune
PostPosted: Fri Feb 19, 2016 8:08 am
I trailer my TI back and forth from Fairfax, Virginia, to Ocracoke, NC (about 360 miles) at least twice a year. I always leave the seats in and never have had a problem. Having said that, I also usually try to strap my paddles down in such a way that they also cover the seats and hold them down too.
PostPosted: Fri Feb 19, 2016 8:18 am
For any real distance I put my cover on, so I guess the cover would keep the seats in place.
"Third Normal Form"
  • Trampolines
  • Hobie cover
  • Davis Spar Fly
  • Spine Board Hakas
PostPosted: Fri Feb 19, 2016 8:27 am
I also just fold the seat down and use the mirage drive bungee to secure. I trailer my TI about 60 miles round trip each outing, no issues so far...
-- Chad | 2014 TI
PostPosted: Fri Feb 19, 2016 6:15 pm
I tried folding them down but the curved backs stick up fairly far and get in the way. I lay the sail down the center of the hull and can't do that with the seats in.
One very humid morning I took my Outback somewhere a few hours away. When I arrived it was PLASTERED with bug guts! So VERY glad I didn't leave the seat in then! :)
PostPosted: Wed Feb 24, 2016 10:45 am
I usually don't remove them when transporting and hold them down with the sail/mast on top. Less stuff to setup when getting to the launch spot.
PostPosted: Wed Feb 24, 2016 2:11 pm
That's my own agenda: trying to get launch/retrieval down to the fewest possible minutes.
Just got a set of cradles and I can see they are going to go a long way towards cutting down the current 28-30 minutes trailer-to-sailing-ready that I am getting carrying it taken apart and upside-down on the trailer.
I made it in under 10 minutes once on my H-16...and I think that time might be in the cards now for the AI.
PostPosted: Sat Feb 27, 2016 6:27 pm
For efficiency at the ramp you could add a sail holder to your trailer (this idea was originally from Sun e Sailor around 2011). Having a sail holder means you can leave your seat snapped in and you won't need to bag or unbag your sail any longer. It will save time launching.
You need to find 5" PVC pipe which is quite hard to source. And you'll need to melt it with a heat gun to squeeze it between the crossbars (not too difficult). I also fabricated a strong bracket for the front of the trailer to support the pipe. Everything I used besides the PVC was from hardware I had in the garage. Since Sun e Sailor's pictures are no longer active, here's pics of my version.
I can't recommend the trailex trailer enough. So easy to work with and reconfigure.
PostPosted: Sat Feb 27, 2016 8:59 pm
Nice work, Jim!
PostPosted: Sat Feb 27, 2016 9:09 pm
Very nice!
"Third Normal Form"
  • Trampolines
  • Hobie cover
  • Davis Spar Fly
  • Spine Board Hakas
PostPosted: Sat Feb 27, 2016 10:36 pm
Having fitted a skipper seat to my MY12 TI, I needed to make a raised support near the stern, so that I could carry the mast lying along the deck. (Photo shows initial travelling position of mast, which was too vulnerable to damage from road schrapnel...)
In addition, I preferred to have a separate lightboard (thought process assisted by some b^stard cracking one of the original trailer taillights...)
So I solved both problems by building a small pyramid-shaped structure from marine ply and broomstick. This and the lightboard are held in place by the standard bungees in the rear cargo area. When I lay the mast along the deck, it goes under those crossed bungees, through the gap under the folded seat back, and then secured at the bow using the forward hatch bungee. All touching surfaces are protected by wetsuit material.(Tip#1: you can often pick up gratis torn wetsuits from local diveshops...)
Tip#2. Hi vis rudder cover made from $10 safety vest (can make two from each vest)
PostPosted: Sun Feb 28, 2016 2:37 pm
CaptnChaos wrote:
...you could add a sail holder to your trailer
I have been carrying the sail laying on top of the beach wheels and along the top of the hull.
A little needlework in the sail bag so there are snap connectors holding it to the beach wheels and to the bow - plus a belt-and-suspenders extra safety line at the bow.
https://picasaweb.google.com/1081497986 ... 1569294370
