It is currently Wed Aug 05, 2026 11:25 am
 Post subject: Roller Furler Rebuild
PostPosted: Thu Feb 25, 2016 11:55 am
I am in the process of rebuilding my Hobie 21 SE Jib Roller Furler... I am replacing all the plastic parts as well as the small ball bearings that might have wear... The question for all of you is..... does this area need grease or some kind of lubricant???
Thanks Looking forward to getting back on the water soon.
Currently snowing here in Michigan
JEM135
Hobie 21 SE
Hobie 16
E Scow
PostPosted: Thu Feb 25, 2016 12:50 pm
Yes! I use axle grease for my furlers, main car and jib tracks. Not only does it hold the bearings in place during install, but I find it lasts the longest.
PostPosted: Thu Feb 25, 2016 12:52 pm
I rebuilt mine after breaking the outer drum. If my memory is correct, I order a rebuilt kit from Hobie and it work fine with a little lube. Good luck....spring is on it's way............ :D
Bill 404 21SE
PostPosted: Wed Mar 02, 2016 10:45 am
I too used grease on the bearings. I used a marine white lithium. So far, so good.
Watched the America's Cup world series in Oman last weekend, making me REALLY want to get back on the water!
One more month and the weather should be doable :-)
-Todd
Todd
Hobie 21SE
Bellingham, WA
