It is currently Sat Aug 01, 2026 12:27 pm
PostPosted: Mon Mar 21, 2016 7:12 pm
Las Vegas is gonna be over 112 to 115-deg F this summer ; and i'm getting tired
of burning my hands on the black anodized parts.
Their going to get White paint (.)
What kind of paint should i use ?
How should i prep the parts ?
Thanks : Bille
PostPosted: Mon Mar 21, 2016 9:53 pm
Paint gets scratched off easily. I used black auto trim paint on an anodized frame and it looks like hell, especially on the front member where the jib blocks make contact.
Better off with a carpet kit on the side rails as these are the ones you're probably touching the most.
JKK
83 yellow/ white decks Hobie 14 Corando turbo
82 yellow hulls Hobie 16 Cat Fever
84 yellow hulls hobie 16 Yellow Nationals
plus a few extras that I'm restoring
PostPosted: Wed Mar 23, 2016 9:27 am
it's true that paint will scratch, but it's better than burning hot bars.
epoxy paint is what I'd try, a spray job will give an even coat.
or see if electrostatic powder coating will work on the aluminum (costly and needs a contractor for the job).
there are some forms of hull paint that may work as well, again costly compared to epoxy paint.
I painted my comp tip white many years ago, mostly to keep off the UV damage. maybe I'll go for a florescent color next time :lol:
Chris
'88 H18SE Arís
PostPosted: Wed Mar 23, 2016 3:16 pm
I have used appliance paint with reasonable results.
It can be scratched, but it lasts pretty well for little time invested.
Todd
Hobie 21SE
Bellingham, WA
PostPosted: Wed Mar 23, 2016 9:49 pm
I'm going with OlderBowman's suggestion , and look for a good epoxy paint ; i'll call
the manufacturer to enquirer how to prep there paint for aluminum.
Epoxy paint is strong ; they even use it in pools !!
Bille
