It is currently Mon Jun 15, 2026 10:48 pm
Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
PostPosted: Fri Mar 25, 2016 12:15 pm
I start with a few large diameter pool noodles, cut to various lengths and wedged into the hull so that any thing loose will stay in the general area of the rear seat hatch where I sit to sail the TI. That is, dry bags can no longer slide clear to the far end of the boat. Being a strong believer in positive flotation in boats, I don’t mind taking up space with foam. I’d even appreciate bulkheads, but am not enough of a DIY kind of guy to make them.
When I say the foam keeps things in the general area of the the rear seat, that is still a vast area. I once spent a week looking for a bag with my wallet. TI space is truly amazing. So I narrow it down further with the squarish wide mouth clear plastic jars that mrbrightwork mentioned. I get em at Costco rather than Sam’s Club.
The one I’m holding is for 1.13 kg (2.5 lb) of unsalted cashews. It is 7” high, 5” square, with a 4.25” opening for a screw top lid. The label glue comes off with mineral spirits if I’m ambitious. I have some bigger ones for pub mix snacks — 5.5” square and just under a foot high. My open fist fits easily into the openings. The smaller one holds over half a gallon (2 l), the bigger probably twice that.
These are great: buy the jar and get the pretzels for free! Hobie should sell them because on their sides they fit nicely into the rounded curves of the hull bottom. Thus they do not slide sideways, and you can line them up on each side of the hull, narrowing the space for real storage so that dry bags do not slide sideways too far from the hatch. Mostly my jars stay empty. But they’re great for water ballast, sand or pebble ballast, positive flotation air, bringing pretty rocks or plants home (I ‘m always always gathering plants that I want to look at later with a botany book and a microscope), drinking water, and of course dry storage for lunch, gloves, hats, glasses, phones, etc. Or just leave the pretzels or animal crackers in them.
They are not certified dry, but the lids do screw on tight, and on their sides the lid opening is about a centimeter or two above the curved hull bottom. I’ve never found water inside them even with a fair amount of water sloshing around the hull. I use slide lock bags rather than zip lock (I’m genetically zip lock impaired). I find that about 80% of slide locks are 100% water proof. But since I don’t know which 80%, I never trust them. I would however trust anything to stay dry in a slide lock bag inside a Costco jar. I’d also guess that a thin gasket of neoprene or rubber could be cut out & fitted to the lid to guarantee them dry.
As I recall, Ikea also has kitchen jars that may work in a similar way.
After shortening the hatch access space with pool noodles, and narrowing it with plastic jars, I end up putting most of my stuff in dry bags close to the hatch. A dry bag can come out quickly and the hatch closed up while fishing through the bag. This minimizes open hatch time. I would never open the front hatch, or even the rear one while on the water.
Love the ideas here for zip ties and biners, and the flexible tub idea.
Brian
PostPosted: Fri Mar 25, 2016 9:35 pm
At the seat hatch I use a deep gear bucket that I have modified by gluing a thick piece of foam to the bottom that is cut to just fit the space between the bottom of the bucket and the hull. I don't use the bucket lid at all. Now the bucket sits on the hull rather than hanging from the rim of the hatch where it will inevitably fall through. The foam is the same diameter as the bucket bottom.
I also drilled holes around the bottom of the sidewall of the bucket so that water drains out of it because water always ends up spilling in when the hatch is opened. This way the bucket acts like a colander, things may get wet but the water drains out.
I think Tony's Trug idea would work great in combination with this for larger items.
In the forward hatch I keep about four pool noodles and a yoga mat to corral ( Yee Haw ) things.
Chris
PostPosted: Fri Mar 25, 2016 11:26 pm
My storage solutions on my AI are:
1. For gear I want to keep dry.
A 5 or 10ltr dry bag works well, and can either be put in the hull, or clipped to the rear Aka. I find this does not move around inside the hull. I also use a Hobie storage tub.
2. For gear I don't mind getting wet. Spare rope, extra water bottles, Mirage drive plug, etc, I use rope tidy bags. I have one bungyed to the Aka in front of the Mirage, and another behind the seat. I think these are great, and they don't interfere with the pedals at all.
http://www.burkemarine.com.au/products/rope-tidy-bag
Cheers
Colin
PostPosted: Sun Mar 27, 2016 5:06 am
http://us.tubtrugs.com/
Those trugs look very useful to me.
I may have to become a Truglodyte :lol: :lol: :lol: :lol:
sic em Rex !
Chris
PostPosted: Sun Mar 27, 2016 7:15 am
I also have two drybags attached to the crossbar behind... one for ground tackle (Cooper and sea anchors, 6 feet of chain, shackles, 25 yards of extra anchor line (10 yards permanently attached up front), the other my comprehensive safety bag.
PostPosted: Tue Mar 29, 2016 9:16 am
That a great idea, I've been using the deep gear bucket without the lid but haven't added the foam, such a simple solution.
Cuda Kev Frampton
2015 Hobie Adventure Island in Golden Papaya "Sail-Fish"
