It is currently Mon Aug 03, 2026 4:56 am
PostPosted: Thu Mar 24, 2016 6:21 am
Hello as from subject
Can I use exp.foam instead epoxy resin to repair delamination of hulls (60 x 10 cm) area fw of pilone?
I'm on the job right now!
PostPosted: Thu Mar 24, 2016 8:52 am
NO!!!!!
2001 H18 w/SX wings & spinnaker #16740 (purchased new)
1989 H18 w/SX wings #14565 (purchased new, sold 2000)
Would buy another if Hobie would build it.
PostPosted: Sat Mar 26, 2016 1:52 pm
As Neu said.. expanding foam has no strength to it. Also you will probably create moee delam as the foam expands and will push the inside layer further away from the core. The epoxy repair is not that hard to do so just do it right.
Sent from my SGH-T999L using Tapatalk
PostPosted: Sat Mar 26, 2016 2:19 pm
Drill shallow holes through the top layer and fill the void with GetRot. If you are careful to fill he whole area, it will resolve the problem permanently. Search this forum; there are MANY discussions with instructions.
