It is currently Mon Jun 15, 2026 7:14 am
PostPosted: Tue May 10, 2016 1:01 pm
Not quite sure where else to put this, but my wife and I are wanting to spend more time racing this year and are contemplating a roof top tent or slide in camper for our truck.
I'm looking for ideas to help me figure out if the mast will clear it when we're towing. I'm just not a fan of driving around and waiting for a loud "bang" when we tackle a steep incline.
PostPosted: Tue May 10, 2016 5:49 pm
I have seen lots of Hobie's behind RV's and slide in bed campers. The trick is to raise the front mast support high enough to clear. Might need to modify the front support to allow for adjustment. I have seen some extreme angles to clear large RV's, also need to watch out for how low the rear gets.
Scott
Hobie 18 w/wings
Hobie/Holder 12 Funseeker
2 Hobie Waves
Tandem Oasis Kayak
Hobie 16
Southern California
PostPosted: Tue May 10, 2016 11:20 pm
I have no problem to tow the Wildcat beind our camper
I raised and reinforced the front mast support
F18 Hobie Wildcat sail nr NED 066 & NED 1111
Hobie 16 sail nr 104195 sold
470 sailnr NED 560 sold
PostPosted: Wed May 11, 2016 6:30 am
Now that's a mast support......How did you determine how much taller it needed to be to clear the camper?
We're strongly considering a roof tent for our truck that will sit about 18" above the roof of the truck when folded and I have about 24" of clearance when trailering.
PostPosted: Wed May 11, 2016 7:00 am
If you go with a pop-up style in bed camper, you will have more clearance for the mast (and improved gas mileage since it's lower profile while driving). Other options would be to extend the length of the trailer tongue, use a trailer hitch extender, or just slide the mast back farther on the trailer so the mast doesn't overhang the truck.
PostPosted: Wed May 11, 2016 3:35 pm
I cut the mast support in two parts and ad another piece in the middle
With a long fishing rod i tried the free space between the mast (fissing rod ) and the camper
In our street actualy where the picture is taken is a speed hump
with the trailer on the way down and the camper on the street whe did check the clearance again
Mastsupport is about 2,5 m
