It is currently Tue Jun 16, 2026 6:05 pm
 Post subject: Tiger Hull cracks
PostPosted: Thu Sep 07, 2006 4:02 pm
I recently noticed a thin vertical crack along the very front edge (bow) of the hull(both)where the hull is joined together. Has anyone encountered this? I am probably going to sand off the gel coat to see how deep the crack runs, although I can't believe it goes through to the interior.
I have not hit anything so I am assuming it is a natural seam crack.
Any help would be appreciated.
Thanks Thomas
 Post subject: Tiger
PostPosted: Wed Sep 13, 2006 11:00 am
The Tiger hulls are "Clam shell" two halfs joined down the center of the deck / keel / bow, so a visable "crack" may be crazing over a bit of flex the hull went through. The gel coat could be thin maybe. Photo?
 Post subject: Re: Tiger Hull cracks
PostPosted: Fri Jul 15, 2011 5:34 am
Matt I have 2 spots on a Tiger hulls I just bought and they are all the way thru the seam water leaks thru them any ideas on a repair technic? Looks like the last owner tried to just use some filler but it did not work. I will add photos of the other crack if it will help I think its longer but its on the seam too.
Floyd
00 Tiger
http://www.HobieFleet33.com
10 Mile Surfside, Texas
Join us on our Facebook group: Surfside Sailing
PostPosted: Fri Jul 15, 2011 8:44 am
Drug on the beach and over time wore through some of the glass. You need a basic bottom job as done on other boats for keel wear. Even a 16 can wear through to an actual gap. Grind off the gel coat. Layer glass along the keel. Smooth, fill and gelcoat again.
PostPosted: Fri Jul 15, 2011 8:59 am
I was thinking about grinding out the seam some and filling with http://www.westsystem.com/ss/new-six10-epoxy-adhesive/ then doing a bottom job. There really is not much beach wear wear it seems like the seam came apart I have the same thing on the other hull in a different place with even less beach wear. Thanks for the quick reply Matt!!
Floyd
00 Tiger
PostPosted: Mon May 16, 2016 7:13 am
Hi
I am close to purchase a Tiger from 1996.
Any known weak spots that year?
What worries me a bit - under the rear crossbar there are many small/thin 'spider-like' cracks in the gelcoat. If I lay a hand on that area I can feel it is not 100% flat as well. But it feels solid if I press on it).
Any thing to worry about?
Best regards
Fredrik
PostPosted: Tue May 17, 2016 1:25 pm
Image is not available.
I've got no great experience with Tigers, Not many issues over the years... so defer to others on this.
