It is currently Thu Aug 20, 2026 5:41 pm
PostPosted: Sun Jun 05, 2016 10:44 am
Hey folks,
I'm currently doing a restoration job on my ancient Hobie 16 trailer. One important item I'm currently missing is the mast rest, which attaches to the top of a mount on the front of the trailer.
If anyone can identify just exactly who manufacturers a Hobie 14 to 18 mast rest which would fit into this mount, I would be incredibly appreciative. Thank you!!
Photos of the mast rest slot:
PostPosted: Sat Jun 25, 2016 2:40 pm
This might help:
I've never seen a mast support like that - especially aluminum on a steel trailer. That support already has a crack in it. I'd replace the whole thing. It's not rocket surgery.
PostPosted: Mon Jul 18, 2016 11:25 am
Looks to be a home made stand. It probably had a bow stop stuffed into it.
JKK
83 yellow/ white decks Hobie 14 Corando turbo
82 yellow hulls Hobie 16 Cat Fever
84 yellow hulls hobie 16 Yellow Nationals
plus a few extras that I'm restoring
PostPosted: Mon Jul 18, 2016 10:52 pm
I'd be getting rid of that pretty quickly as it looks like aluminum extrusion and will not only rust quickly but i wouldn't trust it to hold a mast above my car.
There are lots of great trailer shops these days that makes DIY setups as easy as using Lego for trailers. I'd get a new length or galvanized steel high enough to clear your car and add a yoke piece to the top. Then you can place clear tubing over this or just wrap it up with cloth/foam.
2007 Hobie 16 - 'Slingshot'
1996 Hobie 18 - 'Onrails'
Hobie Bravo - 'Hobie Bites'
