It is currently Mon Aug 17, 2026 8:16 pm
PostPosted: Tue Jun 07, 2016 11:27 am
One issue with the Eclipse is you cannot stop or go backwards.
So, it would be neat to be able to have some type of clips on the handlebars that we could attach a paddle to in case needed.
Any ideas?
PostPosted: Tue Jun 07, 2016 9:23 pm
H-Rail accessories attach well to the handle bars. You could clamp a paddle holder there and rest the blade on the deck.
PostPosted: Wed Jun 08, 2016 10:51 am
Ideally looking for a clamp that can connect to the vertical bar going up, not the handle bars.
PostPosted: Wed Jun 08, 2016 3:19 pm
Did you check out -- UNIVERSAL MOUNT / CAGE
This awesome adapter allows you to mount a water
bottle cage or small device to the handlebar tubing.
Quick attacment and removal. Adjustable for upper
or lower tube size.
72020503
UNIVERSAL MOUNT -- it goes on the vertical stem; I'm sure you could 'rig' something to hold a paddle.
PostPosted: Wed Jun 08, 2016 4:23 pm
Do you have a web link to this? I cannot find anything under 72020503 part number
PostPosted: Wed Jun 08, 2016 5:17 pm
Page 12. -- http://cdn.hobiecat.com/digital_assets/ ... August.pdf --
PostPosted: Sun Aug 21, 2016 11:21 am
Here is what I did: Image
PostPosted: Mon May 29, 2017 7:54 am
Hi RogWild,
I'm interested to see what you did but I can't see your image. Any chance you could re-submit? Thanks.
PostPosted: Thu Jun 15, 2017 8:05 pm
Here is a picture of what I did. Pool Noodle to protect deck, and velcro to hold paddle shaft to handlebar column.Image
PostPosted: Thu Jun 15, 2017 8:08 pm
Here's a 'side view', only need one velcro strap to hold it; easy to get it out. Image Bungee through the 'pool noodle' to keep it in place. Small 'loop' at end of velcro strap, to make end easy to find.
PostPosted: Sun Jun 18, 2017 9:47 pm
that's good , thanks for sharing!
goldenslot
