It is currently Mon Aug 03, 2026 12:36 am
 Post subject: H16 bridal GoPro mount
PostPosted: Wed Jun 15, 2016 7:53 am
By popular request here is the GoPro mount I made. It was constructed using a 2in x 1/8th in piece of aluminum. At one end it it the full 2in height and is secured to my wind vane with 2 bolts on one side and 1 bolt on the other. I created a second small piece so it sandwiches each side of the neck of the wind vane. I had it extend a few inches back to allow clearance for me expanded battery pack and back door floaty. To secure the gopro I used the straight adapter that came with the expanded battery. I bolted that to the aluminum which fit perfectly between the 2 prong side of the adapter.
Catamaran Racing Association of Michigan - Marketing Officer
USF18 - Social Media Manager
2010 NACRA Infusion
2004 F18 Hobie Tiger - SOLD
Hobie 16 - BREAKPOINT - SOLD
PostPosted: Thu Jun 16, 2016 10:06 pm
Looks good, and simple enough that I could see myself making one too. How does it do? Do you feel like the GoPro affects the windvane at all? The GoPro would be downwind of the TeloCat, and pretty small, but they're a little blocky. And does the extra weight pull down on the TeloCat so the ring is jammed on the holder? Or does it still hold pretty well? And how are the videos? Can you post some footage?
Pat
78 H16
PostPosted: Fri Jun 17, 2016 8:58 pm
I just saw your previous post (Breakpoint) where you showed some pictures of you sailing, and I'm guessing those came from your GoPro. They look good. I was wondering if the mast was going to dominate the picture, but it doesn't at all. Nice work!
Pat
'78 H16
