It is currently Fri Jun 05, 2026 3:32 pm
Post new topic Reply to topic  [ 321 posts ]  Go to page Previous  1 ... 16, 17, 18, 19, 20, 21, 22  Next
PostPosted: Sun May 22, 2016 11:28 am
vetgam wrote:
Now I tend to sail upwind as far as I can so that I can then jibe back using the spinnaker near a beam reach to maximize the time with it up and the adrenaline rush. It's become my favorite sail on the boat.
On the downwinder, do you furl the main and sail on spinnaker only?
2017 Trailex 450 Trailer
Pre-September 2015 cradles
eMail: [email protected]
PostPosted: Sun May 22, 2016 3:23 pm
I sail the spinnaker with the main all the way out most of the time. Sometimes I'll furl the main to the first baton and leave it there while jibing.
Greg
2016 AI - Spinn & Jib
– Charles G. Davis
PostPosted: Mon May 23, 2016 10:08 am
PeteCress wrote:
tonystott wrote:
Peter, how can you find space for as 21 inch piece of pvc on the halyard. Maybe the AI reacher is shorter in relation to the mast than the TI...
Yes, that appears to be the case. ..... Mine might even take 24".
FYI, I am selling my SpinKit and moving on: viewtopic.php?f=7&t=57713
FWIW, it's not the furling issue - which has been resolved to my satisfaction, nor is it the halyard's effect on sail shape, which I could probably learn to live with.
Instead, it is all that additional line laying around..... It's just not "me"..... One attraction of the AI for me is it's simplicity.... and the SpinKit's halyard and sheeting lines defeat that for me. .... Entanglement, limited grey matter and all that... Especially entanglement.
This may not work on your boats because of the routing of the lines and since your spin bags are on the wings, but I was able (on my boat) to route the halyard so that it was the snuffing line as well giving a continuous loop. That eliminated a lot of line. I think on your boats you would need to add a separate line to pull the tack out to the bow, but that might be less of a mess...but it might not. I confess my boat has quite a lot of lines that get messed up often (sheets for spin and jib; halyard/snuffer for spin and jib; mainsheet); it helped some that I replaced a lot of the yachtbraid with something that was single braid to prevent kinking.
R/Thom
SeaRail 19
Triak
BMW C600
Formerly raced F24 Mk II
PostPosted: Tue May 24, 2016 1:02 am
You have described Hobie's system to a T. A continuous line starts at a grommet in the upper third (AI) or quarter (TI) of the spinnaker, snaking through these grommets and entering the snuffer bag. I believe the line then goes forward into a cleat on the front crossbar, to a block and tackle sub-system which is tied to the tack of the sail. It then returns to the rear of the hull, through a block where it becomes the backstay. At the mast head, the line passes though two bearings in a small mast top beam, and down to tie off at the head of the sail. Independently, there are sheets leading to swivel cleats on the rear crossbar.
PostPosted: Tue May 24, 2016 10:19 am
Hey, that's pretty clever of Hobie to have a continuous guy/halyard/snuffer. SO, I gotta ask, where is all the tangle potential for entanglement? If you have loose line; cut some off, right? If the loose sheets bother you, then simply reverse the line, instead of a luggage tag at the clew, tie both ends to the clew giving you another continuous loop (or just tie the two sheet ends together with a square knot). Granted, having a continuous sheet gives the opportunity for being unable to dump the asymspin if it gets tangled.
R/Thom
SeaRail 19
Triak
BMW C600
PostPosted: Sun May 29, 2016 8:29 am
I made a few changes in installation, because I did not want to make holes in the akas. In this way they can be easily disassembled.
first I made this hole wider.
Then I use screws from YakAttack GearTrac - GT175
Then I cut out unnecessary plastic.
Done!
PostPosted: Sun May 29, 2016 3:07 pm
i consider the railblaza holder for aka too expansive for the task they have to accomplish. this is a cheaper thing that can be used when u need put anyathing on your haka such as in this case but also rod holders, camera holder, hook for keeping the mailsail like out for dowwind and so on. I found them in this forum on another subject
http://www.ebay.it/itm/391347241873?_tr ... EBIDX%3AIT
PostPosted: Mon May 30, 2016 4:05 am
Great finding! Almost 10 times cheaper. Maybe less stylish, but who cares? :) THANKS
PostPosted: Mon May 30, 2016 4:20 am
Thanks for that, I had forgotten about the Harley fork attachment option! But... I am having trouble seeing the problem in just drilling a few holes in the akas and using Hobie's supplied fittings.
My eyes started to water when I totted up the cost of that Railblaza alternative, all to save drilling a few holes. I love the Railblaza aka fitting, and have three on my TI already, so I am not anti-Railblaza.
PostPosted: Mon May 30, 2016 4:48 am
Me neither. I like Railblaza and I have several of them in my boat. But having a cheap alternative is always good :) It open possibilities for new tests and ideas (not necessarily just to avoid the holes for the spi)
PostPosted: Wed Jun 01, 2016 11:57 am
Here is the rest of the mods :)
PostPosted: Wed Jun 01, 2016 4:33 pm
Very tidy setup, thanks for sharing the photos. There are cheaper options out there but your railblaza setup looks very professional.
PostPosted: Thu Jun 02, 2016 8:38 am
Very nice, but awfully expensive with those big sheave blocks and attachments. Bullet blocks will work fine for the wimpy loads you will see. Blocks can be tied to the frame with line-if you want neat, make a continuous loop splice around the aka. The half twist shackle is a good idea and Hobie should change the part in their kit.
R/Thom
SeaRail 19
Triak
BMW C600
PostPosted: Sun Jul 10, 2016 12:12 pm
I have found that the PCV pipe at the mast head used to pevent unrecoverable halyard tangles is not working in higher wind when the wind blows the pvc towards the main sails batton while furling. I have found 2 things that will probably work but I have yet to try on the water. One was to loosen the tie on the uppermost batton cap. This seems to allow the batton to curl inward more when furling. This is likely to make it less likely for the batton to catch the halyard line. This may account for the reason some have had issues with snagging and others have not.
BEFORE
AFTER
The other solution was to attach Pex tubing to the top of the mast topper and run the halyard through the pex tubing. This tubing flexes yet retains it shape. When the batton hits the tubing, the tubing remains in place because it is firmly attached to the mast topper. If it was just dangling, it tends to rotate with the sail batton and snag with the main. Driveway tested only. Will report back when stress tested on the water.
Greg
– Charles G. Davis
PostPosted: Mon Jul 11, 2016 10:39 am
The second solution seems very promising. Looking forward seeing the results of the live test in the water
