It is currently Tue Aug 11, 2026 12:43 am
 Post subject: 2016 TI and Mystery Nut
PostPosted: Sun Jul 17, 2016 4:16 pm
Hi All
I just received my new 2016 TI yesterday and spent today checking it out.
I found a very small steel lock nut with nylon insert in the bottom of the boat.
Its the same size as those used to trap the steering chords on the rudder.
I cant see if its come loose from somewhere inside the boat.
Any thoughts as to where it came from inside???
Should I be worried or happy to add it to my spares box?
Many thanks
Pottsy
2016 Tandem Island (Red)
PostPosted: Sun Jul 17, 2016 5:36 pm
They seem to drop something into almost every boat I've helped setup. It shouldn't be a problem. With that said I would check every nut/bolt and screw for tightness. Every boat I've help setup had something loose, maybe from transport.
Enjoy your new boat!
PostPosted: Sun Jul 17, 2016 7:15 pm
My first thought is that it could have come off the set screw that holds the mast receiver cup to the bottom of the hull. There should be a 1/4" nylon lock nut there. Like KayakingBob suggests I would definitely check the tightness of all bolts and screws and even use loc tight, if it's not on there already, on anything that is loose.
-- Chad | 2014 TI
PostPosted: Mon Jul 18, 2016 3:46 pm
Thanks all.
I checked everything inside and out. All appears to be ok.
I have it in my spares box now.
Sent from my SM-N9005 using Tapatalk
PostPosted: Mon Jul 18, 2016 5:47 pm
"They all do that."
:D
Peter
