It is currently Sun Aug 02, 2026 10:22 pm
 Post subject: ZEP Question
PostPosted: Mon Jul 18, 2016 4:37 am
For all of you ZEP users out there, I have 2 easy questions:
1. Have you ever used the ZEP sealer prior to the Wet Look Finish? The wet look is step 3 of their 4 step process. 1 is strip. Got that covered by bar keepers friend & wet sanding. 2 is sealing. Necessary or not? While I was buying the wet look product I saw the sealer right next to it so I bought a gallon, now debating whether to use it or not. It is almost as expensive as the wet look. May do one hull with sealer and one without, just to see, but I would rather just do both the right way, whatever that is, if anyone knows.
2. Step 4 of their process is maintain, which sounds like just washing occasionally with a mild detergent. I guess when all goes wrong, you go back to step one and strip everything off. So the question: what do you guys do to maintain? Wash and reapply every once in a while? Ever have a need to strip the Wet Look off or does it naturally disappears over time with boat use?
Thanks for any advise or direction. My home lake, Monroe reservoir in Indiana has a lot of red clay in it and tends to stain an unprotected boat very quickly.
 Post subject: Re: ZEP Question
PostPosted: Thu Jul 21, 2016 1:34 pm
I've never heard of ZEP but if you want to protect your boat and you have all the stuff I would certainly use it all.
Now I'll look into this product, I just used zing Hull cleaner on my ol boat and it looks so much better, was just going to polish and wax it but maybe this stuff is really great?
PostPosted: Sun Jul 24, 2016 5:04 pm
I looked for ZEP at home depot without any luck. Is this an acrylic floor finish?
JKK
83 yellow/ white decks Hobie 14 Corando turbo
82 yellow hulls Hobie 16 Cat Fever
84 yellow hulls hobie 16 Yellow Nationals
plus a few extras that I'm restoring
PostPosted: Mon Jul 25, 2016 7:21 am
I've used both..... I think after a really good cleaning the wet look finish by itself looks the best after about 4 coats with :30 min between coats. The sealer didn't seem to add benefit IMHO.
Tim Grover
Memphis, TN fleet 134
Hobie 20! G-Cat5.0 and 2 Hobie 14's
Photobucket now wants $100 to post pics on forums......... pass.
