It is currently Thu May 14, 2026 2:01 am
PostPosted: Thu Jul 14, 2016 6:10 am
I just installed the Hobie battery kit in mt Outback. Easy to install, and seems to be very secure in holding the battery. The battery is sealed, so I don't think there would be an issue, but when I store my Outback, I store it upside down on a rack. Therefore, the battery is also upside down also. Could there be any kind of problem doing this? I started thinking about it last night, and pulled it out this morning just to be safe, but if there isn't a problem with the battery being upside down for long periods of time, i won't worry about it anymore. Thanks for the help!
PostPosted: Thu Jul 14, 2016 7:34 am
The battery is a "gel cell" construction, so it will not leak.
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Thu Jul 14, 2016 8:26 am
That's what I thought. I didn't see anyway for it to be a problem, but you never know..........Thanks!
PostPosted: Sat Jul 16, 2016 6:20 am
Depending on how long you are going to store it, you might want to take it out and put it on the trickle charger.
PostPosted: Sat Jul 16, 2016 6:26 am
I remove mine after each outing...my Revo is heavy enough to load on top of my SUV without the extra weight. That little sucker is heavy.
PostPosted: Sat Jul 16, 2016 6:29 am
Just how long can the battery can be idle without a recharge....thinking about next winter...
PostPosted: Mon Jul 18, 2016 11:31 am
We recommend pulling the battery out and recharging it immediately after each use, then unplugging the battery once fully charged. Storing your battery in a discharged state may inhibit your battery from holding a charge. Also, during periods of long-term storage, we recommend charging your battery once a month.
Howie Strech
Parts & Accessories Product Manager
PostPosted: Mon Jul 18, 2016 11:58 am
Thanks.....
