It is currently Fri Jun 19, 2026 4:47 am
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Thu Aug 18, 2016 8:49 am
Yakass wrote:
I'd have to say nothing I'm aware of makes me favor Hobie's multi-lube over Inox/Lanox
The advantage is for the environment. It is also a very good lube.
PostPosted: Thu Aug 18, 2016 5:42 pm
But the Lanox does not arrive for a couple of weeks and the replacement chain/cables will arrive in the next few days.
What would you do?
- Just rinse and wait for the Lanox to arrive
- Apply something else (if so, what?)
I wouldn't let the lack of lube for a couple weeks stop me use the kayak, but it wouldn't hurt to squirt a bit of WD40 on the chains/swages in the meantime. Just make sure it gets rinsed good and proper after use, and for best effect use warm water. WD40 rinses off quite easily, so when the Inox arrives just rinse the drive good and proper, you won't see any contamination issues. I agree with the comment that you should avoid spraying WD40 in sprockets and drums because it is a dispersent that might upset the grease.
Lanox is pretty resilient and hangs on much better than WD40 and I was able to get away with spraying the drive down every 2nd or 3rd trip without ever seeing any rust. Thorough rinsing is the key - if you are diligent with that and use a good lube you shouldn't need to spray each time. Mind you, don't let that comment stop you from doing it.
By the way, a member here posted a pretty clever modification on this forum some time ago that I got curious about and trialed to success. That was to coat the swage with some good marine grease (really rub it in) and then put some quality heat shrink over the top of that to seal it in. That seem to work for me, although after a year of use I decided it was overkill for me because I wasn't having any problems any way.
Kayak Fishing Specialist: SLH
https://slhobie.com.au
PostPosted: Thu Aug 18, 2016 5:48 pm
I did read that it is environmentally friendly. I'm not sure its much more environmentally friendly than Inox+ or Lanox, though I am entirely prepared to believe it is. I figure you guys would have good reason to recommend the stuff. However, claim is that Inox+ (MX5) and Lanox (MX4) is non-toxic, so I am guessing that stuff is relatively environmentally friendly compared to a lot of lubes on the market. Either way I'll be using the Hobie-multi-lube from here on in, though I'll be paying more attention to the anti-corrosion performance than anything else.
PostPosted: Fri Aug 19, 2016 8:28 am
Would you eat Inox+ or Lanox? The Hobie Multi Lube is an enhanced mineral oil and you could drink / eat it. Our dealer in San Diego has been using it for a few years and loves it.
PostPosted: Fri Aug 19, 2016 6:02 pm
fusioneng wrote:
...those cables are under high stress and much flexing, so you can assume the cables will fail over time, there isn't much that can be done,....can't take the constant flexing and tensile load as would be required by a cable.
Seems like cable in this situation is just a bad idea.
An $80 consumable is something I would try to avoid.... even if I could get three years out it.
Can anybody comment on why Hobie doesn't just extend the chain all the way? .... I would not think it would cost that much more because the stainless steel chains I use on my single-speed bikes only cost $12.00 retail for a rather long chain..... also, they would save the cost of the interface between the cable and the chain....
The benefits I see are:
  • Repairable: a chain tool, a few spare links....
  • Longer lasting: I get about 5,000 miles from a bike chain and those replacements are only because of the misfit between a worn chain and the steel cog on the rear of the bike.
  • What you see is what you get: no hidden corrosion because of salt water wicking up under the plastic cover. ..... i.e. vastly-reduced chances of on-the-water surprises.
Seems pretty obvious to me - but I'm not an engineer and the physical world is probably a vastly-simpler place to me.....
Tangentially: Does the third cable (the one with no chain attached... that runs up over the wheelie thing in front) fail also?
I'm starting to think of the Mirage Drive in terms of pre-emptive replacements.
2017 Trailex 450 Trailer
Pre-September 2015 cradles
eMail: [email protected]
PostPosted: Fri Aug 19, 2016 10:06 pm
I have been rocking my Revo since 2010 with the original cables. When I got my used 2013 AI, I went ahead and replaced all the cables and tuned up the drive as I don't know the extent of salt use prior to my taking.
Anywho, I have always taken the cables and put them in a food sealer bag, added a copious amount of Corrosion-X to the bag and then vacuum sealed the bag. With this I left it over night to let the Corrosion-X really permeate metal and all the cable strands.
In doing this, I haven't had to replace a cable due to a breakage yet.
PostPosted: Sat Aug 20, 2016 6:29 am
INSAYN wrote:
...I have always taken the cables and put them in a food sealer bag, added a copious amount of Corrosion-X to the bag and then vacuum sealed the bag. With this I left it over night to let the Corrosion-X really permeate metal and all the cable strands.
Do you still spray the cables with WD-40 or INOX or something after washing? .... or would that wash off the Corrosion-X?
PostPosted: Sun Aug 21, 2016 4:54 pm
Haha... nope... but I wouldn't eat Kale either. Nor would I eat Hobie Multi-lube for that matter. I'm not doubting Hobie's lube is the most environmentally friendly. Nor am I doubting it as being equally effective as a lube (I'll have a fair idea by the end of summer). But its only been available to Hobie dealers recently, whereas I have years of experience with Inox/Lanox and I feel I can safely recommend them. They certainly perform better and are less toxic than WD40, which is what a lot of people have been recommended to use on Miragedrives
PostPosted: Mon Aug 22, 2016 8:08 am
Yakass wrote:
... I have years of experience with Inox/Lanox and I feel I can safely recommend them.
Do you think there is anything to be gained by submerging/soaking new cables in Lanox for a day or two before installing them?
I'm thinking maybe the stuff would wick up into the cable, dry out, and perhaps reduce the wicking of salt water in use.
PostPosted: Mon Aug 22, 2016 9:42 am
Pete:
That is actually a very good idea. Wicking in any 'water displacing' (hydrophobic) lubricant into the cable (via vacuum) should certainly help, in addition the lubricating ability helps ease the friction of the individual strands rubbing against each other as the cable flexes (90 % cause of failure). This could conceivably double/triple the life of the cables.
What occurs (because of the friction), is as the cable flexes thru it's motions, some individual strands experience an unfair individual load, having lubricant in the bundle of cables, helps relieve some of that friction, maintaining equal load across all strands (the key to everything).
With the intrusion of salt water into the cable, it is entirely possible the normal lubricity between each strand is compromised (the strands sticking/rusting together). This will greatly shorten the service life of the cable (likely 10 fold). Possibly going with a TIN (titanium Ion Nitrate) coated wire may extend the service life, but likely an expensive process.
Easier to just to soak the cables in some hydrophobic lubricant in a food saver machine (most of us have them in our kitchens) when you get them (or just a vacuum bag and your vacuum cleaner, us wooden boat guys do vacuum impregnation all the time (ie... that's what it's called).), this prevents salt water intrusion into the wire bundle.
Moving forward that's what I plan to do.
great ideas.
FE
PostPosted: Mon Aug 22, 2016 12:55 pm
Well, the stuff arrived today.... and either I ordered wrong or they shipped wrong but what I have is INOX MX3 instead of MX4/Lanox.
Everything I have read indicates that Lanox is better for marine use..... But, reading between the lines, I gather the benefit is mainly in greater persistence and if I am diligent about spraying with MX3 it should be good enough.
Anybody disagree?
PostPosted: Mon Aug 22, 2016 7:12 pm
Yep, I do think that is a good idea. I do it myself once a year, every time I service my drive, which I do leading up to my annual expedition to Fraser Isl. The drives spent over a week submerged in salt and rarely rinsed in those trips. Never see rust at the end of them, so yeah, I think this helps
PostPosted: Tue Aug 23, 2016 5:59 am
Yakass wrote:
...I do it myself once a year, every time I service my drive, which I do leading up to my annual expedition to Fraser Isl. The drives spent over a week submerged in salt and rarely rinsed in those trips. Never see rust at the end of them...
I am guessing that you qualify as a heavy user.
That being the case, how many years do you use the cables before (I assume...) pre-emptive replacement?
One person's practice of carrying a spare Mirage Drive on long trips is starting to make sense to me.... not that I will ever take a long trip...
PostPosted: Tue Aug 23, 2016 11:25 am
I always carry a spare drive when I sail my AI's (The TI's inherently having a spare). With that said, the only drive that has rusting is my spare drive and only on one side (the side that faces up). I wonder if the repeated splashing of sea water then drying might be causing that or the hot sun on it. I hope to make a cover for it to see if it helps. It gets washed off after every trip, but doesn't look good. Other than the rust, it looks almost new.
PostPosted: Tue Aug 23, 2016 11:41 am
zarbs wrote:
I use Inox MX3 or MX5 (Inox plus)
After you spray all the SS pieces with INOX, how diligent are you about wiping off the overspray/excess?
Since this is going to be an oft-repeated process, I'm trying to figure out an SOP that takes the least time, but does the job.
One extreme is to slather everything with INOX and then hang the Mirage Drive somewhere where the drips won't hurt anything until the next use - and let the in-use sloshing with salt water take care of excessive built-up on the non-SS parts.
The other extreme being to carefully wipe everything clean....
