It is currently Fri Jun 12, 2026 2:07 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3
PostPosted: Tue Aug 23, 2016 7:01 pm
I am guessing that you qualify as a heavy user.
That being the case, how many years do you use the cables before (I assume...) pre-emptive replacement?
One person's practice of carrying a spare Mirage Drive on long trips is starting to make sense to me.... not that I will ever take a long trip...
Good questions. To be honest I have never done a pre-emptive cable replacement (never needed to), though I usually sell off the kayak I am using after 2 - 3 years to get into a newer model. But you can take that to mean I have been able to make the chains/cables last that long without any failures whatsoever. Also no rust or performance issues. And for about 6 years I was using my kayak more than anyone I know, and pretty much all of it in open ocean waters.
That said, we do take precautions on our annual expeditions. In the early days a couple of the guys were too relaxed about maintenance/servicing (against my advice) and sure enough they ran into issues and have learned their lesson. We haven't had a problem in the last 6 trips, and we usually cover about 300kms per trip. Typically the group is about 6 people. There are always 2 spare chains, 2 spare sprockets and 2 spare masts between us.
I have done pre-emptive chain replacements for customers many times. I often suggest it as being a good idea if there is visible rust on the exposed cable, especially if it looks like it has penetrated the steel cable, which if left to fester eventually will.
Kayak Fishing Specialist: SLH
https://slhobie.com.au
PostPosted: Tue Aug 23, 2016 8:07 pm
PeteCress wrote:
zarbs wrote:
I use Inox MX3 or MX5 (Inox plus)
After you spray all the SS pieces with INOX, how diligent are you about wiping off the overspray/excess?
Since this is going to be an oft-repeated process, I'm trying to figure out an SOP that takes the least time, but does the job.
One extreme is to slather everything with INOX and then hang the Mirage Drive somewhere where the drips won't hurt anything until the next use - and let the in-use sloshing with salt water take care of excessive built-up on the non-SS parts.
The other extreme being to carefully wipe everything clean....
I personally don't bother about wiping everything clean. I spray all the cables/nuts, chains and pedal adjuster & pivots, I also have some Inox in a small oil can that I use to lube the drum shafts (let it run down the shaft a couple of times) and idler drum. I haven't found that the Inox affects the drive material but I do keep it away from the fins, just in case it has a reaction to the rubber. Obviously the closer you get with the spray nozzle the less overspray you will get and the less 'cleaning' needed, and I haven't found a build up (as yet).
PostPosted: Wed Aug 24, 2016 6:40 am
Yakass wrote:
There are always 2 spare chains, 2 spare sprockets...l.
What is the failure mode for a sprocket? Something that one can see coming?
I am building a replacement part inventory. So far, a couple of fin masts and a chain.
2017 Trailex 450 Trailer
Pre-September 2015 cradles
eMail: [email protected]
PostPosted: Wed Aug 24, 2016 4:05 pm
Depends entirely on how well the user keeps chain tension roughly where it should be. 99.9% of instances where we see damaged sprockets is due to the user letting the chain get too loose (usually people who bought second hand kayaks, and were never shown anything they needed to know). Loose chains can damage sprocket teeth, especially if the user is pedaling hard.
Sprockets are otherwise incredibly reliable. I have never damaged one myself. The spares we take on expedition are really just a precaution, because if one does get damaged its a show-stopper. We can't allow that because we are no where near civilization and have a long trek back to mainland. We rely on those drives because we can't always rely on wind.
