It is currently Wed Aug 12, 2026 4:09 am
 Post subject: Width of seat PA14?
PostPosted: Mon Sep 05, 2016 11:38 am
Can someone please measure the width of the seat between the arm rests? I'm a big guy and concerned that the seat my not be wide enough? Do the various years differ? I know the seats have changed, but not sure about changes in size.
 Post subject: Re: Width of seat PA14?
PostPosted: Mon Sep 05, 2016 7:33 pm
My 2016 PA14 Vantage Seat measures 20.75" at the narrowest point between the arm rests.
PostPosted: Mon Sep 05, 2016 8:32 pm
My 2013 PA-14 seat measures 20.5" and the rated capacity is 350 pounds maximum. So very close to Jim_MI measurement.
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Tue Sep 06, 2016 12:10 pm
Inside of the arm rests on the Pro Angler's Vantage seat are currently ~21" apart. Feedback from customers looking for a wider Vantage seat has been taken into consideration.
Howie Strech
Parts & Accessories Product Manager
PostPosted: Thu Sep 08, 2016 2:22 pm
Are there any good alternatives for aftermarket seats? Armrests are a plus as with bad knees it would be easier to get up out of the chair.
PostPosted: Thu Sep 08, 2016 8:49 pm
On the PA-14...if the seat is in the upper or elevated position, it is easier to get up....the arm rests are quire nice and robust.
You could also consider adding the Hobie H-Bar http://www.hobiecat.com/accessories/h-bar/
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Fri Sep 09, 2016 8:46 am
As Dr.SteelheadCatcher said...the H-Bar (part no. 84500114) is a great addition to the PA 14 and is helpful for:
    *Pulling yourself up from a seated position
    *Assist entering the kayak
    *Leaning against for stabilization
    H-Bar features adjustable height settings
Howie Strech
PostPosted: Fri Sep 09, 2016 10:40 am
Looks like a great solution...except when sailing I could see a conflict with sail.
PostPosted: Fri Sep 09, 2016 3:44 pm
The H-Bar can be quickly and easily folded forward to be out of the way by removing the quick release pins on the rear feet. This still gives you access to your front hatch.
For a quick overview of the H-Bar, check out the link to our H-Bar accessory page: http://www.hobiefishing.com/accessories/h-bar/
Howie Strech
