It is currently Fri Jul 03, 2026 7:35 am
 Post subject: Paddle with handlebar up
PostPosted: Mon Jan 09, 2017 8:43 am
I would like to know if it is possible to paddle the Eclipse with the handlebar up. I would be interested in switching back and forth between the peddles and the paddle while on the water.
PostPosted: Mon Jan 09, 2017 2:47 pm
Possible, but difficult. You need to swing the paddle across in front of you. Easy enough to remove the handlebars I would think. Be sure you strap down well.
PostPosted: Tue Jan 10, 2017 6:41 pm
It sounds like it would be easy to remove the handlebar while out on the water, so I could just strap it down and paddle. I am also assuming that it would be easy to re-install the handlebar while on the water also?
PostPosted: Wed Jan 11, 2017 9:20 am
Yes.
