It is currently Mon Jun 15, 2026 7:55 pm
PostPosted: Mon Jan 23, 2017 2:50 pm
I have a mirage drive 180 and have already bent (slightly) the mast. Can someone walk me through removing the fin and removing the mast.
PostPosted: Mon Jan 23, 2017 3:41 pm
Here's a video for working on the 180:
https://www.youtube.com/watch?v=u2BwZLCNV5o&feature=youtu.be&ab_channel=HobieCatCompany
And here's how to remove the boom:
https://www.youtube.com/watch?v=IGahQM_TDzA&feature=youtu.be&ab_channel=HobieCatCompany
Jacques Bernier
http://www.hobie.com/
PostPosted: Mon Jan 23, 2017 3:45 pm
Detach the aft adjuster. Remove the fin. Clamp the mast in a vise and use the drive to leverage the mast straight.
PostPosted: Mon Jan 23, 2017 6:45 pm
Thanks Matt. Everything worked just like I knew what I was doing.
PostPosted: Tue Jan 24, 2017 5:52 am
Thanks Matt. The videos were the kind of information I needed. The mast is straightened.
PostPosted: Sun Dec 24, 2017 1:50 pm
Ugh, bent mine today badly. The fin also split some on the seam on the shaft. Thanks for the videos, looks like I'll have to try and make it work until the next time I get off this island to try and get parts. --- kinda shocked it bent so easily
PostPosted: Sun Dec 24, 2017 5:08 pm
Why aren't they made of fiberglass rods?
Also saw a video suggesting to straighten it using the coupler on the trailer hitch where the locking pin goes
PostPosted: Mon Dec 25, 2017 4:42 am
To straighten masts without a vice I face drive down on ground so sprocket shaft is pointing upwards, pedal pads flat on ground and mast pointing out in front of you. Then either stand or kneel on pedals to hold drive. Slip a length of steel tube, I use an old galv standpipe and lever straight. Be careful not to over correct or bend it on a different axis as the less bending you do the better. When tip to tip dimension=base to base dimension it is done. Usually its just the front mast but double check the rear one before using as a measure.
