It is currently Thu Jun 18, 2026 5:44 pm
 Post subject: Pro angler rudderh
PostPosted: Tue Feb 07, 2017 11:44 am
I need to know what size/type of bit is required to remove rudder on my 2014 pro angler. Any heip is greatly appreciated!
 Post subject: Re: Pro angler rudderh
PostPosted: Tue Feb 07, 2017 4:08 pm
What are you drilling?
On the rudder attachment to the housing, should be a slotted screw head on one side of the rudder and a phillips on the opposite.
PostPosted: Tue Feb 07, 2017 5:07 pm
I can't find screwdrivers that will maneuver into the area to remove the slotted and Phillips so was trying to remove entire assembly from the top (under the black access panel) so I can get to the to afore mentioned screws. Am I on he wrong track? Was looking for the driver bit that fits the bolt that releases the rudder assembly.
PostPosted: Wed Feb 08, 2017 8:59 am
Remove the cover on the deck to access the rudder system. Remove the mount screw that is holding it to the drum - then it will drop down and you will be able to remove the sister screws at that time.
Jacques Bernier
http://www.hobie.com/
PostPosted: Wed Feb 08, 2017 10:08 am
We are talking in circles. The original question was the specifics on the holding screw. Is it a Tory, hex, L, and what size? T15, T25, L2, H10?? I am trying to avoid buying an entire set of bits when I only need one.
PostPosted: Wed Feb 08, 2017 12:13 pm
We use Alen screws - they are not Torx. The cover plate used a #2 philips - the drum is held on with either a Alen screw or you have a push pin that wouldn't require any tool - since we don't know which version you have it could be either of those
Current boats are using a philips screw - so again, just a #2 philips is required....It's hard to know which version you have - you really just need to open it up and have a look.
The screw is #8030126 it's a 10/32 x 3/8" long - it requires a 1/8" Alen wrench
Jacques Bernier
PostPosted: Wed Feb 08, 2017 3:23 pm
Or may be a Philips. Would be interested to hear what you have. Our BOM (Bill of Materials) and parts diagrams note the hex, but the factory is currently using a truss head phillips.
