It is currently Tue Aug 04, 2026 7:05 am
PostPosted: Thu Mar 01, 2007 2:09 am
Hobie Team Member
Matt
Is there a tech note on installing the single handled hatch?
I finally had to break down and order one due to leaks. But no instructions came with it from dealer. Are they online somewhere?
Also no screws came. I can see I need 8. Do the old ones work? If so I can probably pickup the other 2 at Ace?
 Post subject: Hatches
PostPosted: Thu Mar 01, 2007 10:16 am
Dan,
There are two part numbers where you can get an 8 inch hatch. One is just the hatch #71702. The other is a retorfit kit with the needed two screws and instructions #71702001.
The instructions are on our support pages: http://www.hobiecat.com/support/pdfs/Tw ... ctions.pdf
The screws are stainless and fairly standard I think, so perhaps you can find them over there. #10 x 3/4" PHSM
PostPosted: Thu Mar 01, 2007 11:36 am
Hobie Team Member
I'll try to get it installed this wekend.
Between your instructions and JJ's photos on KFS seems pretty clear.
PostPosted: Thu Mar 01, 2007 6:58 pm
Dan,
You have an earlier Adventure and may have a warped opening. It's no big deal, but check it out with something flat to see where the high and low spots are. If so, I'd recommend sealing the gap with a generous bead of silicon caulk when you install you new hatch. If it gets outside the joint, just wipe it up.
You will re-use your 6(?) screws plus whatever Matt says the other two are.
Finally, part of your leakage is probably coming from your drive as it swishes water into the hull and right up to your forward hatch where it's probably been leaking in. You can block this by crafting a "swish blocker" from a foam block (the flexible kind that doesn't crumble). It would look like this:
Original gap:
Block taped on rear of drive:
Block installed:
Crude but effective! Note it stops short of touching the drive cables. Also, remember that extra speed you were looking for? This will give you almost .1 MPH at cruise speed -- a respectable start on your goal of .5MPH -- and for no extra effort!
Hobie should consider coming out with something like this.8)
PostPosted: Thu Mar 01, 2007 10:41 pm
Hobie Team Member
Man I have to try that swish thing!
About another two weeks though. Too many things piling up like my Otter Board stuff.
