It is currently Sun Aug 02, 2026 3:29 am
PostPosted: Fri Apr 07, 2017 5:55 am
Currently my hobie 16 has nothing on the rails, an I need some grip for being out on the wire. Would a spray on neoprene product work? Would it be too thin or not grippy enough? What are some other alternatives? I was also thinking maybe a plasti dip with sand underneath. What do you guys think? Thanks!
PostPosted: Fri Apr 07, 2017 9:35 pm
My boat has the original factory applied neoprene, but I don't think it was sprayed on, looks like it is two separate thick pieces on each rail.
Marty
1984 H16 Yellow Nationals Redline, "Yellow Fever"
Lake Martin, 'Bama.
PostPosted: Tue Apr 11, 2017 12:27 am
For a spray on, would you be referring to something like a bed liner coating? You would need something that would bond well, the plastic coating may peel easily. You would want something that stays cool. I have seen outdoor carpet used, glued down with contact cement. I guess it's cheaper than the rail rug kit. What ever you do you don't want it to interfere with the tramp track.
Since the boats are assembled by dealers there is no such thing as factory installed rail rug. A dealer may install it as an option, I would guess.
JKK
83 yellow/ white decks Hobie 14 Corando turbo
82 yellow hulls Hobie 16 Cat Fever
84 yellow hulls hobie 16 Yellow Nationals
plus a few extras that I'm restoring
PostPosted: Tue Apr 11, 2017 3:52 pm
I have the neoprene rail kit from Murray's ( https://www.murrays.com/product/30-210/ ). I've only sailed with it once but I like it so far. It's soft and grippy and goes on with contact cement.
"Stray Cat"
1981 Hobie 16 Gonzo
Harstine Island, Wa
PostPosted: Tue Apr 11, 2017 5:23 pm
Has anyone tried the peel-n-stick? Just wondering which one works better, the peel-n-stick or the contact cement.
PostPosted: Wed Apr 12, 2017 9:17 pm
What I meant by "factory" is that the neoprene on my boat is original to the boat, whoever installed it, but thanks for the clarification. :D
Marty
Lake Martin, 'Bama.
PostPosted: Sat Jun 26, 2021 6:58 am
WRT to neoprene and rail kits, I am redoing the rail kit for my old H18. I have heard neoprene has issues re UV and rot from water damage. Anyone have opinions or knowledge on this?
PostPosted: Sat Jun 26, 2021 10:58 am
Don't forget you will also be sitting on the rail, so what type of pattern do you want pressed into your buns by the rail covering?
Tim
84 H16
82 H16
87 H14T
Tortola Sails: 115222
Blue Prism Sails: 88863
Clearwater, FL
PostPosted: Sun Jun 27, 2021 7:09 am
I used adhesive backed rubber strips that were meant for bathtubs. They were non-skid, waterproof, and easy on the feet. They lasted a quite a while. They were also one of the cheapest solutions.
Howard
PostPosted: Mon Jul 12, 2021 3:42 pm
I bought a sheet of Hydroturf (https://www.hydroturf.com/category/hydro-turf-sheets/sheets-pwc/) and now I just need to cut the strips for the rails which I'll attach using contact cement (same as the neoprene kits).
PostPosted: Mon Jul 12, 2021 5:06 pm
I just bought a sheet of hydro turf also. I bought a SUP/surfboard sheet with 3M adhesive.
https://www.hydroturf.com/product/flat-heavy-brush-sht23f-psa/
Bryan
Poplar Grove, IL
1977 Hobie 16 (died a spectacular death https://youtu.be/Y7O22bp2MVA)
1978 Hobie 16
