It is currently Thu Jun 18, 2026 1:01 pm
PostPosted: Sat Sep 16, 2017 5:14 pm
Mmiller announced new crank arms for the MD 180.
mmiller wrote:
....And the ARC pedal cranks.
Unfortunately there were no pics, so I borrowed an image the Hobie web site and this is what they look like (with Turbofins):
The first thing you notice is that they are ovalized tubular aluminum. Next, you see they are curved (thus presumably their name). Then you wonder what happened to the squeeze-handle pin adjusters on the sides. They have been replaced with push buttons at the top of the units.
I was lucky enough to try these out recently and they feel very robust. The new push button pin retractor is easy to push, making pedal position adjustment quick and simple. As you can see below, you can even adjust with your feet on the pedals, for instance, if you need to change to a modified "flutter" stroke position to pedal in shallow waters.
Because of the arch in the cranks, your pedal position ends up being about an inch closer (about 1/2 pin distance) to your seat. In order to maintain maximum power, you ideally want full leg extension on your pedals without them hitting the stops. If readjusting the pin position doesn't get you the right leg position, it is possible to reverse the arms, as seen here (with ST fins):
Since these cranks are wider than the old version, the drums have been widened to accommodate them. If you're wondering about whether these new crank arms also come with the GT Drive, I understand that they do NOT. It looks like they can be retrofitted, however, but you would also need the new drums. Check with Hobie to verify this. 8)
PostPosted: Sun Sep 17, 2017 5:48 am
I disagree you want “full leg extension”. You want it just short of that.
Knee slightly bent when stroked out, like a bike.
2017 Tandem Island in Red. Lake sailing/kayaking in NH only.
PostPosted: Sun Sep 17, 2017 9:27 am
Interesting RR, looks promising. Mswlogo, when we say full leg extension we mean ending with a slight knee bend (not locked out) as in biking, which you are correct is optimum. The reverse problem is usually the case where there is to much knee bend because of lack of space for bigger folks.
Mark
Tandem Island- 2013
2 - Sports - 2014
PostPosted: Tue Sep 19, 2017 8:29 pm
What's full benefit of this change , is there a issue with the first 180 drive . What's cost of up grade in full .
PostPosted: Wed Sep 20, 2017 8:19 am
Stronger, more ergonomic - cleaner profile, easier pedal adjustments and better pedals. There is no upgrade being offered for ARC pedals this year. As typical, the factory will be using all available materials on new complete MD180s for new boat production. Even the MD180s for parts sales will have the older pedals.
