It is currently Fri Jun 12, 2026 6:17 am
PostPosted: Sat Nov 11, 2017 6:48 pm
Has anybody switched over to 6:1 on their 14. Looking for a lower stack height and not so much for purchase power. 5:1 is plenty for me.
Saw a Getaway with a triple on the bottom with a double on top with a becket which is 5:1.
Is anyone using the 8mm (5/16) mainsheet? Opinions?
PostPosted: Mon Nov 13, 2017 11:11 am
I use my 16 blocks on my 14 (triple upper and lower) modified as such
(only works with carbo upper with hole through center of block)
Untie sheet end at lower block
Run sheet through center of upper block and put a figure eight in bitter end
Voila, you have a 5:1. Definitely low profile
Pretty sure my Salsa is 8mm
Have H192 lower and 40mm upper
Zings through nicely and easy on the hands
1984 H16 "Mister Rogers"
1984 H14 "Sundays"
2000 H20 "Jet"
Sheet In, Max Out
PostPosted: Mon Nov 13, 2017 4:01 pm
I have 6:1 on my H14. It works nicely. I too have 8mm Salsa main sheet and really like it.
You might want to look at the pdf “Setting Up a Hobie 14”. From the pictures it appears that both Wayne Schafer and Bob Curry are using 6:1.
http://hobieclass.com/hobie-tuning/
PostPosted: Wed Nov 15, 2017 1:21 am
I purchased an 89 Hobie 14 turbo and it came with the triple block setup. Anyway it came from some one who didn't know alot about sailing as it had some fat nylon rope for a mainsheet. I'll have to look into the 8mm, as I'll be using these blocks for another 14 I'm restoring. I'll be selling the 89 as a standard 14. just bought it for parts. Someone put portholes in front of the pylons so I don't trust it as a turbo.
JKK
83 yellow/ white decks Hobie 14 Corando turbo
82 yellow hulls Hobie 16 Cat Fever
84 yellow hulls hobie 16 Yellow Nationals
plus a few extras that I'm restoring
PostPosted: Wed Nov 15, 2017 11:07 am
Agreed that 5:1 is plenty for the 14
I can bend my boom with my 16 blocks rigged as 5:1
1984 H14 "Sundays"
2000 H20 "Jet"
Sheet In, Max Out
