It is currently Tue Aug 11, 2026 7:06 am
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 6 posts ]
PostPosted: Wed Nov 15, 2017 3:47 pm
We have received some reports of steering drum screws coming loose. We have been using an allen head screw that is pre-treated with a Loctite strip along the threads. This has not been holding. We are changing back to a Phillips head screw and adding a drop of Blue Loctite to hold.
I highly advise checking this connection on your boat.
PostPosted: Sun Jun 03, 2018 1:06 am
Is this problem to be looked at on a 2018 PA12
PostPosted: Mon Jun 04, 2018 2:30 pm
Not hard to check. I would regardless of year model.
PostPosted: Wed Jun 06, 2018 8:52 pm
That Allen head screw on my 2014 PA-14 is still tight :D
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Fri Aug 31, 2018 7:42 am
Seems I don't need to worry. Why would a screw design superseded this lock pin design?
Thank you,
Roy Niswanger
PostPosted: Fri Aug 31, 2018 8:56 am
The screw is much easier to install than the roll pin :wink:
Dr.SteelheadCatcher
Warrenton, OR
