It is currently Tue Apr 21, 2026 12:54 pm
 Post subject: “84 boom questions
PostPosted: Mon Jan 29, 2018 7:59 am
Hi everyone. I picked up an ‘84 last fall an have been gradually getting it ready for spring. I’ve a couple of questions regarding the boom. I assume it’s priginal. Has the old Seaway double tangs.
About 2.5 feet back of the gooseneck is another tang (smaller than the aft tangs). What’s it for? About 6 ft back there are two plastic cleats on each side. What are they for?
Ralph
 Post subject: Re: “84 boom questions
PostPosted: Mon Jan 29, 2018 10:08 am
I believe what you describe is for a boom vang, a line that would go from that attachment down to the base of the mast. I know some of the H-16 booms had that but don't think they ever used the vang. The purpose of the vang is to keep the boom from rising when on a reach or a run. I used to sail a Cape Cod catboat (monohull) with a very large sail. On a downwind run there was a danger of the boom going almost vertical, then crossing over and refilling with air with a lot of force. It is called a gull wing jibe. The trouble was you couldn't put a boom vang on that boat because the boom was too low at the mast.
Howard
PostPosted: Mon Jan 29, 2018 11:05 am
I knew that attachment point was for a vang, but always assumed that it was not needed because its a catamaran and the rear traveler, even when let out for down wind, can go significantly further port or starboard than a mono-hull of comparable sail size.
Catamaran Racing Association of Michigan - Marketing Officer
USF18 - Social Media Manager
2010 NACRA Infusion
2004 F18 Hobie Tiger - SOLD
Hobie 16 - BREAKPOINT - SOLD
PostPosted: Mon Jan 29, 2018 1:49 pm
I have a 1984 model also, but it doesn't have anything like that on the boom. The boom is original to the boat and has the old Seaway 5:1 set up, but nothing close to the mast. Wonder if there was a change sometime in '84, or maybe you have an older model?
Here is a pic to show what I am talking about. Image
Sent from my SM-G955U using Tapatalk
Marty
1984 H16 Yellow Nationals Redline, "Yellow Fever"
Lake Martin, 'Bama.
PostPosted: Mon Jan 29, 2018 3:10 pm
Mine has alum mast and tramp frame. But boom is black. Came with sails, org and yel, that are 84 (state registration says 1984). But sail number is 17, so I assume they were a race issued set. I’m gonna try to get photos posted.
PostPosted: Mon Jan 29, 2018 3:43 pm
Here’s a pic
PostPosted: Mon Jan 29, 2018 3:46 pm
It is a boom vang tang. They were never really used for the reasons discussed above with the major drawback being that if you forget to release it during a jibe, bad things happen. The other drawback is that the tang is a metal piece that hangs down from the boom, ready to scrape the crew’s head if they don’t duck low enough. Drill out the rivets and take it off - your crew will thank you.
Not sure what the other cleat is for. Definitely not stock. Maybe used as part of a reefing system for the mainsail.
PostPosted: Mon Jan 29, 2018 3:54 pm
Here is a pic from my Hobie 16 Assembly Manual. For what it's worth, I am also including a pic from Royce's Sailing Illustrated that shows the boom vang thing. As recommended, I would just remove the thing. ImageImage
Marty
Lake Martin, 'Bama.
PostPosted: Mon Jan 29, 2018 4:04 pm
I’ll yank it. It’s pretty useless and a great way for the crew to need a couple stitches on the back of the head.
PostPosted: Mon Jan 29, 2018 4:46 pm
I wonder if the cleats on the side of your boom could be for the outhaul adjustment? I've only seen the outhaul cleat mounted to the underside of the boom but I don't see one on yours.
Marty
Lake Martin, 'Bama.
PostPosted: Mon Jan 29, 2018 5:14 pm
The stainless outhaul cleat is there. The plastic cleats lock onto line pulled to the aft end - just the opposite of the outhaul.
PostPosted: Tue Jan 30, 2018 12:37 am
With the 84 on up the vang bracket was left off and the outhaul cleat is no longer stainless, but plastic instead.
JKK
83 yellow/ white decks Hobie 14 Corando turbo
82 yellow hulls Hobie 16 Cat Fever
84 yellow hulls hobie 16 Yellow Nationals
plus a few extras that I'm restoring
