It is currently Sat Jun 27, 2026 11:30 pm
 Post subject: Compass kayak carrier
PostPosted: Wed Feb 21, 2018 11:29 am
What are you using for carriers on your trailers? I just bought a Malone extra light for my compass and need some ideas for straps also. The Malone uses cross rails and I'd like to not use PCV pipe.
Dave
PostPosted: Wed Feb 21, 2018 12:11 pm
Simple - flip the kayak upside down flat on the crossbars - that is the best and recommended way to carry any kayak.
Jacques Bernier
http://www.hobie.com/
PostPosted: Wed Feb 21, 2018 2:10 pm
What about straps, would it be better to use S hook ends to wrap around the load bars?
Dave
PostPosted: Wed Feb 21, 2018 4:08 pm
Simple cinch-straps is all you need
72042001
TIE DOWN STRAPS HOBIE- 12 FOOT
US$ 21.99
Jacques Bernier
PostPosted: Thu Feb 22, 2018 8:57 pm
I load my Compass upwards and attach 2 additional straps through the scubber holes to avoid slipping.
Easier to push on top that way in my eyes And with added straps I doubt it moves.
These came with super solid straps.
Rhino-Rack Wrap Pads with Board Straps, Set of 2, 700mm https://www.amazon.com/dp/B01966CQEG?ref=yo_pop_ma_swf
PostPosted: Thu Mar 01, 2018 9:03 am
Loading a kayak right side up can cause issues with distorting the hull bottom - or worse case, pressure point loading on scuppers causing damage. The deck is a much stronger flat section of the hull to rest on - that's why we always recommend upside down.
Jacques Bernier
PostPosted: Thu Mar 01, 2018 10:57 am
Thank you.... so far was only able to take the Compass out twice... (need better weather soon)
Next time I will load it upside down.... may actually be easier that way.
