It is currently Wed Mar 25, 2026 6:57 pm
Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2
PostPosted: Wed Mar 14, 2018 4:20 pm
Got it. Thanks Matt.
PostPosted: Thu Mar 15, 2018 9:33 pm
chadbach wrote:
For the last year or so, I've been playing around with shrouds to help distribute forces. When hiking out and trying to keep the boat level, they alone give some boost to the boat since they keep the sail from spilling as much wind. This, of course, makes the boat noticeably less stable, so watch out. I only use them if the jib is out or when I want a more active ride - hiking out and trying to squeeze out a little more speed.
Do you have any closer pictures of your jib setup (furled, unfurled, sailing,) and the hull reinforcements?
PostPosted: Fri Mar 16, 2018 6:02 am
Matt I wonder in which condition "Penguinman" folded the bow. 15 knots? 20?
In my opinion the jib and the spi should be furled with more than 10 knots or at least this is how i should use it.
Islands are very slow whit low winds.
I also understand that Hobie cannot sell the jib since some people should probably use it with stronger winds with big danger
PostPosted: Fri Mar 16, 2018 9:49 am
Here you go - https://www.hobie.com/forums/viewtopic. ... 39#p298839
Thought I'd update my TI mods thread with my jib setup.
-- Chad | 2014 TI
PostPosted: Fri Mar 16, 2018 9:51 am
I have no experience with the spinnaker, but I definitely agree with this when using a jib.
-- Chad | 2014 TI
PostPosted: Fri Mar 16, 2018 11:36 am
On the topic of when to put the foresails away, I snuff the spin at about 10mph and switch to the jib + main. Then as the wind picks up I begin to furl the main but leave the jib out. This makes for a very balanced feel of the boat and increases visability. I sail like this up to about 17mph. At that point I snuff the jib and go with a 1/2 furled main.
Greg
2016 AI - Spinn & Jib
– Charles G. Davis
PostPosted: Sat Mar 17, 2018 3:43 am
https://m.youtube.com/watch?v=uQTuHm5vlNA
Not sure if this is going to work plus my video production skill are beyond useless
PostPosted: Sat Mar 17, 2018 6:37 am
Breeze and swell building as I got out of Port Botany local forecast gave max of 14 kms of wind but felt a little more.
https://m.youtube.com/watch?v=94YtSsCUWeo
PostPosted: Wed Mar 21, 2018 2:51 am
From what I heard about Jim folding the hull, it happened when he was sailing quite fast with the jib and then hit a sand bar and while grinding to a stop the force of the wind on the sail THEN folded the hull.
Jim
PostPosted: Tue Oct 05, 2021 7:18 pm
what is the luff leach of that sail thank you
