It is currently Wed Aug 12, 2026 5:44 am
 Post subject: Lawrence Hook2 4 issues
PostPosted: Thu Apr 26, 2018 5:01 pm
I recently installed a Lowrance Hook2 4 in my 2015 PA12. About half the time I cannot get the auto mode to work, the screen keeps skipping and cannot determine the depth. Any idea as to whats going on? I can get it to work in manual mode but it won't show the correct depth
PostPosted: Fri Apr 27, 2018 7:47 pm
Make sure electrical pins are not bent and inserted into the plug.
Reset to factory defaults and if this does not work, call Lowrance or take it back to the seller.
Good luck.
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Tue May 15, 2018 1:31 am
I had a similar issue until I got it out of simulated mode, through hull or over the side?
