It is currently Mon Aug 17, 2026 9:05 pm
Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2
PostPosted: Fri Apr 13, 2018 7:49 am
COsailer wrote:
PS: Am I right in assuming the top of the jib is connected to the short forestay/pigtail before raising the mast then connect the bottom of the jib to the furler to keep the mast up?
Yes....there should be a swivel (for furling) on the lower end of the short forestay/pigtail (as in mmiller's pic) to which the head of the jib attaches.
Also (as mentioned above), the rig (shrouds) should be tight for sailing, but heed flatlander's advice to to loosen it up before attempting to raise/lower the mast. (It's nigh impossible to do either with the rig tight.)
Jerome Vaughan
Hobie 16
PostPosted: Fri Apr 20, 2018 8:07 am
Had the mast and sails up the other day. The home made short forestay caused a problem. It is too short! Unfortunately, it is swaged (probably not the right spelling) permanently to the swivel. This made it hard to get the mast up. there was no slack anywhere and even when up, I couldn't get the stays any tighter. The rake is almost exactly vertical. I have a single plate 10 hole adjuster that I was going to put at the top of the furler. Question is: How does the adjuster attach to the forestay in the jib? Does it just lay on one side of the jib forestay and get attached with a shackle?
PostPosted: Mon Apr 30, 2018 10:33 am
It is supposed to be short and permanently attached (see in photo of mmiller's post)
Is it about 12 inches?
My apologies if this is a stupid question.
Did you have the side stays pinned in the very top hole?
The single plate adjuster goes at the bottom of the jib and attaches to/through the center of the furler.
1984 H16 "Mister Rogers"
1984 H14 "Sundays"
2000 H20 "Jet"
Sheet In, Max Out
PostPosted: Mon Apr 30, 2018 2:18 pm
The main shrouds are on the last hole. I see that the Hobie upper forestay for the turbo is approx. 10" and with the swivel that would make it around 12". I have what looks like an original Upper forestay but it's 7". The homemade one is attached to the swivel. It's even shorter(6 3/4"). When I hook up the 10 hole adjuster to the furler and jib headstay thimble, do I just lay the adjuster to one side of the thimble and shackle them together? A clevis pin would just go through the thimble.
PostPosted: Thu May 03, 2018 10:18 am
Good
Ah-hah
DO NOT do this.
Attach the head of the jib ("jib headstay thimble") to the furler with a shackle.
From my previous post
I have a single plate 10 hole adjuster that I was going to put at the top of the furler. NO
1984 H14 "Sundays"
2000 H20 "Jet"
Sheet In, Max Out
PostPosted: Thu May 03, 2018 8:22 pm
Thanks Flatlander,
What I don't understand is how to attach the single plate adjuster to the jib. The adjuster has to go up one side of the jib or the other and I need something to attach it to the jib headstay thimble. Correct? Then the adjuster attaches to/through the center of the furler as you stated. I do get that. I worry a bit that the adjuster will rub against the jib and wear a hole in it.
Stay with me FL! I'll eventually get it. Keep trying to teach me please.
PostPosted: Fri May 04, 2018 9:59 am
The tack (front/bottom) of the jib has a thimble
Put the hoop of a shackle through this thimble
Put this shackles' pin through the hole in either end of single, 10-hole adjuster plate, and secure to shackle
Now this single plate is dangling for the tack of the jib
Step the mast, "thread" the adjuster plate through the center of the furler and pin it
1984 H14 "Sundays"
2000 H20 "Jet"
Sheet In, Max Out
PostPosted: Fri May 04, 2018 2:37 pm
I am happy that you stuck with it. I finally understand. That's about what I envisioned. It's hard to describe what I'm thinking being such a novice. I'll have to experiment with furling the jib with that shackle in place but in your experience, do you think I can furl the jib with the shackle on the adjuster or will I have to remove it?
Thanks again, You, Rattle and Hum and srm are the best!
PostPosted: Wed May 09, 2018 9:51 am
here's a link to CO catamaran sailors
http://www.rockymountaincatamarans.com/
they're all as helpful as any of us posters here
I'm certain they'd be excited to meet you a local lake, answer all your questions and share pointers
1984 H14 "Sundays"
2000 H20 "Jet"
Sheet In, Max Out
