It is currently Tue Jun 16, 2026 5:16 am
Post new topic Reply to topic  [ 95 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
PostPosted: Sat May 26, 2018 7:17 pm
cpnsoo wrote:
What product did you use to bring the gelcoat back to life?
FiftyDollar
73 HC16 “50 Cent”
PostPosted: Sat May 26, 2018 8:18 pm
Man she's looking good! I really like Meguiar's products. I use Starbright Marine Polish on my boat to keep the hulls shiny and slick but I didn't have oxidation issues when I got it.
Sent from my SM-G955U using Tapatalk
Marty
1984 H16 Yellow Nationals Redline, "Yellow Fever"
Lake Martin, 'Bama.
PostPosted: Tue May 29, 2018 9:40 am
FiftyDollar wrote:
HobieMarty wrote:
Finding the rudder parts shouldn't be very difficult. Someone here may be able to help you out, and search Ebay also.
Thank you. I know I can buy new parts....but this being a 73 HC16, I promised myself I wouldn’t invest too much money until I know its a sailer. In fact, I’m not compounding or waxing hulls until after my maiden voyage. You should see my actual rudder blade fix. I’ll post pictures soon. If I’m understanding the parts guide correctly, I need the following to have complete CAT minus some ropes and cables and maybe a miscellaneous pulley or two.
(1) 10412011 Lower Casting
(1) 10352011 Upper Casting port
(1) 20382011 Tiller Tube and Cap
Tiller crossbar 20520011
FiftyDollar
I have all the parts you'll need. located in N Kansas City
1984 H16 "Mister Rogers"
1984 H14 "Sundays"
2000 H20 "Jet"
Sheet In, Max Out
PostPosted: Tue May 29, 2018 10:26 am
1st trampoline install. Not sure I could get a factory job at Hobie yet....but I feel pretty good about it. It’s upside down. Hiking straps were broken and the underside had better color.
FiftyDollar
73 HC16 “50 Cent”
PostPosted: Tue May 29, 2018 7:56 pm
She’s up and ready to roll. You’ll notice that I’m working on 2 minor spots on starport hull outside.
FiftyDollar
73 HC16 “50 Cent”
PostPosted: Tue May 29, 2018 9:12 pm
I believe that you can have new hiking straps sewn onto your existing tramp.
Marty
Lake Martin, 'Bama.
PostPosted: Wed May 30, 2018 8:09 am
This trampoline too thin to invest in probably.
FiftyDollar
73 HC16 “50 Cent”
PostPosted: Wed May 30, 2018 10:45 am
Water rigging done. Sails are next. I had a forum member reach out that lives close to me and he is going to help me raise sails and look over verything as a whole. He also has a mast extension for my trailer tongue that is bolt on.
FiftyDollar
73 HC16 “50 Cent”
PostPosted: Fri Jun 01, 2018 11:08 am
50 dollar Hobie rolling soon to its new home.
FiftyDollar
73 HC16 “50 Cent”
PostPosted: Fri Jun 01, 2018 12:26 pm
It may be my imagination but the end of the mast over the tow car seems very high. Some one here should be able to tell us what that should be. It can be adjusted by moving the support forward. When I kept my boat in the back yard, the mast would catch on tree limbs or bushes when I pulled it up to the front of the house.
Howard
PostPosted: Fri Jun 01, 2018 12:36 pm
I totally agree. I looked at cutting it down....it’s a one time trip so I’m going for it. I’ve got the mast so it won’t slide back. I know....famous last words.
FiftyDollar
73 HC16 “50 Cent”
PostPosted: Fri Jun 01, 2018 12:52 pm
If you decide that you do want hiking straps, go to your nearest junkyard and ask them if you can cut the seatbelts out of an old car. Then, drop the tramp off at an auto upholstery shop and I bet they'll sew them on for next to nothing.
Truth be told, I'm too tall at 6'4" to really make comfortable use of them. When I did have them I just used them for stowing halyards and possibly a spray jacket.
James
86' Redline Hobie 16
Sail # 76909
PostPosted: Fri Jun 01, 2018 1:50 pm
That is a really nice trailer setup for 80 miles!
FYI, the mast support on the trailer is going to hang up on your bridals if you try to launch the boat from the trailer.
PostPosted: Fri Jun 01, 2018 4:05 pm
You want the mast high enough on the front of the trailer so that you can open your tailgate fully without it hitting the mast. Any amount over that is over kill.
Tim
84 H16
82 H16
87 H14T
Tortola Sails: 115222
Blue Prism Sails: 88863
Clearwater, FL
PostPosted: Fri Jun 01, 2018 5:48 pm
Suggestion for tramp hiking straps. Buy grommet kit, install grommets through the existing stitched on pieces. Then string 3'8 to 1'2" line through them and thread line through foam hvac insulation tubing for feet to slide under and be comfy. Have used this system for years. Works well, every few years replace the foam tubing over line. Tape the ends of tubing to prevent tearing. Looks nice too when done properly.
By the way...beautiful end result on your $50 buck Hobie!
UK Wildcats have 8 now!
1976 H16 27640
1985 H16 89112
