It is currently Sun Aug 02, 2026 9:05 pm
PostPosted: Thu Jun 21, 2018 9:48 am
I have just replaced the standard jib halyard on my Hobie 16 due to wear in the wire after so many years, but when I was taking the clevis pins out of the jib halyard block, I realized that the sheave inside was stuck. I have not experienced a problem raising the jib, but it worries me that the locked up sheave could be causing the wear. Does anyone have recommendations to replace the sheave or sand it down so that it can spin freely?
PostPosted: Fri Jun 22, 2018 8:52 am
The hole in the sheave (that the clevis pin goes thru) has probably worn a lot and is probably no longer round (causing the sheave to bind).
Over the years, I have replaced this sheave twice. Hobie Part#: 61260000
Tim
84 H16
82 H16
87 H14T
Tortola Sails: 115222
Blue Prism Sails: 88863
Clearwater, FL
