It is currently Tue Aug 11, 2026 12:59 pm
Post new topic Reply to topic  [ 45 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sun Jun 24, 2018 7:58 am
Sardinian Islander wrote:
Hi. For the ones who used dp-8010 can you confirm that in order to use it you need to buy so add o the tools and in this way the cost becomes similar of that for the Hobie KC welder?
You can buy a mixing nozzle and plunger, but it is not necessary. I mix by hand (with a stick) as with other 2 part epoxies -- it is less wasteful, but does take several seconds off your short working time. I use dowels to individually plunge the tubes, indexed so each tube gets pushed the same distance.
I just tried a new similar product, Loctite 3035 and am very impressed with the results. It also has a very short working time, but has one advantage -- a 1:1 mixing ratio rather than 1:10 ((easier to blend accurately).
Plastic welding, IMO, is not as strong and is limited as to access depending on location (many drivewell cracks are better addressed from the inside of the hull). Drivewell repairs should be reinforced to be made stronger than the original material, since it obviously failed already. If the crack is in the back of the drivewell, corrective action needs to be taken on the Drive so it is no longer a point of contact. Good luck with your repair! 8)
PostPosted: Sun Jun 24, 2018 10:29 am
If I owned that boat here is what I would do to repair.
Yes if can reach in there and try to weld the crack itself, it will help, but is not really necessary to do so, (no welding will ever be strong enough to fix leak), it will start leaking again quickly.
However the problem can be mitigated so it will never leak again. There are two distinct problems here, one being a crack in the hull (which really can't be fixed effectively), and the other and more serious problem of water coming into the hull. These are separate issues.....
First off there is a flaw in the design of every mirage drive boat made, which is called a point load against the thin web of plastic at the front edge of the mirage pocket. The pressure from your pedaling flexes that little web of plastic till it fails, there is no plastic made that withstand that type of load, (speaking as one of the top plastics experts in the industry).
You can verify the problem yourself easily. Just put the kayak (any Hobie), place in any pool with the bow pointed towards the sidewall. Now with you standing next to the boat, place your finger under the thin web in the front of the mirage drive. Now have someone else start pedaling the boat as if underway. You can feel with your finger that little web of plastic flexing up and down. That's the root cause of the issue, no un-reinforced plastic in existence can withstand that load.
In the beginning of time, (early 2000's) before turbo fins, on the original design the load on that point was much less). Of course Hobie has done much to strengthen the area, but failed to address the root cause.
The simplest solution of all is to eliminate that point load and flexing altogether. It's very simple to fix.
If you go to home Depot or walmart and pick up some bondo body putty, (a small can).
Next remove the mirage drive and clean both the mirage drive well, and the front of the mirage drive, (the front tang) well.
Now spray some mold release, (cooking spray will also work, siran wrap also works), into the front area of the mirage pocket, where the mirage tang sits).
The front tang of the mirage drive, if you rough up the outside surface of the tang on the frame a little, the bondo will stick better.
Now mix up some bondo, about the size of maybe two golf balls, and gob a small amount of the body putty around the front of the mirage drive tang. Now drop the mirage drive in and click it in place, (but don't push it down too hard in the front till it bottoms out in the pocket front).
Now take the rest of the bondo and work in and around the front tang so it completely fills the space in the very front of the mirage well, (covering the tang on the front, top , and sides, (basically filling in the space), and hopefully climbing up the walls a small distance).
Of course the type of putty you end up using is up to you, (I'm outlining the method, not necessarily the material), use what you like. There are several epoxy based repair clays out there that would work nicely, as long as it sets up rigid, and sticks well to the front of the mirage drive tang your golden. I also used white Locktite marine epoxy on one boat, (but it's thinner, you need to make a tape or clay dam to control where it goes). Anything you use, if you ever sell the boat, you can usually chip and sand it off the front of the mirage drive.
Now to test it in the water. Put the boat back in the pool, put your finger back on the same spot, (on the thin web at the front of the mirage well). Have someone else pedal the boat to their hearts content, you will not feel any flexing in that area at all. Job is done.
We used the flex 90 fins on our TI, (same fins used on the eclipse), which are much larger than turbo fins, (on older V2 mirage glide drives, not 180 drives), If you don't do that fix you will wreck the hull. Of course your still going to snap more cables, and the strain on all the mirage drive mechanisms is greatly increased, (shortening the lifespan).
This fix only address's one boat, matching one mirage drive, (the fixed drive can't be used in other boats without re-doing the fix.
Of course this is only one of a hundred ways to address the root cause of the problem.
Now to fix the water leak. It's not worth trying to fix the crack itself, (there is no longer any load on that area, (from the previous fix), basically what we did was enlarge the point load from a 1/4 to 1/2 sq in surface area out to a 2 to 3 sq inch surface area, (well within the flexmods of the plastics being used).
You can fix the crack if you like, but I wouldn't bother, (too difficult, the material is already wrecked, and can't be recovered). So the best thing to do is just make sure it doesn't leak water, ever.
Easiest way to fix is to clean the entire repair area very clean, out to a couple three inches away from the repair area. Once dry just spray a thin clear coat of Krylon for plastics spray paint, (the active ingredient in the paint is heptane, (which melts almost all plastics). Then just get a tube of clear GE silicone and glob it over the entire area, say 1/4" thick, so it's spread out 2 to 3 inches away from the crack with an even coat, (doesn't need to look pretty).
The hull will never leak water again.
The Krylon paint sticks very well to the polyethylene, and the GE silicone sticks very well to the Krylon painted surface so bonding is as good as anything out there. THe silicone is nice and flexible, so any banging around or impacts on the hull don't break the water seal. Think of it similar to a bike inner tube repair kit.
People can talk about all the fixes and repairs they like, (there are a million opinions), not a single one I've ever seen on the forum address's the root cause of the original problem...... Which is a basic flaw in the original design itself, which applies to all mirage kayaks ever made, past and present, (extreme point load).
FE
PostPosted: Tue Oct 23, 2018 1:23 pm
fusioneng wrote:
Which is a basic flaw in the original design itself, which applies to all mirage kayaks ever made, past and present, (extreme point load). FE
Except that the failure rate does not at all support this. Failures to drive wells are very rare these days. We make a LOT of boats, so we will see a few though. Murphy's law and all.
PostPosted: Sun Jul 26, 2020 4:09 pm
I noticed on my 2012 Outback 2 small cracks in the hull just forward of the Mirage drive well. I had a local plastic welder put a few beads of HDPE on and around the crack, but my hull is still taking on some water. About 1/2 gallon on a 5 or 6 hr trip on saltwater in bays and inlets. I take on some small waves and wakes. Attached are photos, i need advice as to how to seal these leaks , may a larger patch. Is this typical of Outbacks after 8 years of use.
PostPosted: Mon Jul 27, 2020 2:18 am
This is of course just my opinion based on owning many hobie kayaks over the years, ( and over using most of them).
The drivewell cracks used to be a pretty common issue, but not so much anymore, (their current design is pretty durable in my opinion.
However the problem can be broke down into two separate issues actually. Issue one is it’s a crack in the material at a high stress point, ( caused by point stress). And second it is a water leak that can be addressed separately.
To prove out the point stress problem simply put the kayak in a pool with the nose against the side of the pool, have someone start pedaling the kayak while you are standing along side. Place your finger just in front of the mirage drive, where the tang makes contact with the hull. Every time the pedals are pressed you will feel the hull move, (thats the point of over stress on the hull, ( it’s just a matter of time-vs power applied before the plastic fails, the more power that is applied, the sooner the plastic fails, ( simple physics)).
Because I was a strong peddler, and typically used over sized fins, this was a pretty typical failure point on most of my Hobies.
After a short time of use you can see the very small point of contact where the front tang of the mirage drive touches the hull, (typically turns black at that point). The trick is to spread that point of contact out over as large an area as possible. I tried metal inserts, epoxy, silicone rubber, etc, ( a hundred ways to fix the root core issue).
Knowing all this, whenever I got a new boat I would typically pour some epoxy or that dp stuff into the area around the tang, (can’t be too thick if too thick the mirage drive won’t latch in). Then with a baggie over the mirage drive tang I put the mirage drive in. What this does is it spreads the point if contact with the tang over a much larger area. This proves out when you place the kayak in the pool and have someone pedal while you feel the hull under the tang, if fixed it no longer moves, ( or moves much less). BTW all this was with older mirage drives, not sure if it still applies with the newer models And mirage drives.
As far as the leaking goes, that’s a separate problem, pretty much every New boat I Bought, before using I would gob in a quarter inch thick layer of GE clear silicone all around the miragedrive well, (inside the hull, doesn’t have to look pretty), going out a couple inches From the well to form a water seal. I also did the same at the base of the mast holder, and any possible future leak points. Don’t worry it can all be peeled away if you ever sell the boat. But if a crack does develop the silicone prevents any water from entering the hull, ( yes I have flooded my hull while several miles out to sea, that really sucks to be sitting in waist deep water not going very fast in a swamped boat, lol).
BTW on a TI the bow is very heavy, once it’s flooded and sinks, the boat becomes a bobber and is near impossible pump out and recover, for that reason I always kept several pool noodles stuffed in the bow area, ( additional floatation). Even in 4ft of water I couldn’t lift the flooded bow, (too heavy). In my situation with the much widened boat, (13 ft wide, and the AMA’s raised 6 inches from normal, the AMA’s no longer kept the boat afloat when swamped, lol especially when way overloaded with passengers and scuba gear, (you needn’t ask how I know this). Especially un-nerving with a half dozen sharks circling the boat, lol, think they like the yellow Hull color.
Hope this helps
FE
PostPosted: Mon Jul 27, 2020 5:43 am
FE
A picture pleas if at all possible of where the heck on the hull are you addressing
I am just a noobie here, getting ready to get (most likely) an AI living on a canal next to Caloosahatchie in Cape Coral, Florida (400 miles of man made canals)
Thanks 4 any reply
PostPosted: Mon Jul 27, 2020 6:14 am
I can’t figure out how to post pictures on the site
PostPosted: Mon Jul 27, 2020 8:10 am
I explained it twice in I thought To be great detail.
When you slip the mirage drive in it is held in place by tangs on the front and back, then latched down by the click and go clamps.
The area I’m talking about is in the front of the mirage drive, ( the little tang or tab that sticks out the very front of the drive, that makes contact with the hull). Only the front tab/tang is of concern, the rear tang doesn’t experience any stress at all, ( no need to re-enforce the rear tang).
Sometimes trying to fix the crack itself causes more damage than the crack itself. If you apply the two fixes I outlined, you can ignore the crack, just leave it. Get rid of the sharp point load and seal the outside of the drivewell with silicone, the fix should last for years, and the boat won’t leak water. The water leak is way worse than the crack in my opinion.
FE
PostPosted: Mon Jul 27, 2020 1:47 pm
Thank you for the replies and advice...i was able to locate the crack from inside the hull, following the concept of increasing the strength of the hull, not just sealing from water, would it be advisable to patch ,with a flexible fiberglass patch and not weld from the inside of the hull.I wish i could post pictures but there is no option to attach photos.
PostPosted: Mon Jul 27, 2020 2:07 pm
As you stated earlier the crack exists , forget about the crack , seal the hull and fill the drive well around the drive to relieve the singular contact point and the stress...ill try it .
PostPosted: Sat Aug 21, 2021 7:50 am
I'd like to thank @Fusioneng for his post here, and kick this back up to the top.
I've had a hell of time with leaks around the drive-well on both an Outback (probably 2011 hull?) and Adventure, which is I believe a 2013. What was incredibly frustrating was the dealer, Great Outdoor Provision Co. in Raleigh, being unable to fix or even identify the leak, despite explaining very carefully it only happened when using the Mirage drive. All the soap-and-water and pressure tests, were pointless.
I went with a plastic welder and stainless mesh and welded the mesh just in front of the well, and a bit inside, on the exterior of the hull. That helped a lot -- got maybe 2 years before the leak started again, and I could see my weld was failing.
Recently, tried Fusioneng's approach with Krylon, silicone (actually used Flex-Seal paste, instead) and bondo on the front tang of the drive. I worry that bondo will eventually fall off, but right now the drive is rock solid, although the gray chunk of bondo looks like hell.
IMO, at least with these older boats, combining really active use in all conditions, a strong peddler, and turbo fins....that's a lot of force on a tiny area. My friend who has a couple of Hobies, as well, has the exact same problem with an older Revo13.
PostPosted: Sat Aug 21, 2021 10:54 am
Lol, we had 8 different Hobie mirage boats over the years and used the daylights out of them pretty much every weekend, typically in offshore conditions in the keys where we really shouldn’t have been, in heavily overloaded boats and typically way too many passengers, (we loved to scuba dive the coral reefs).
For a while we had a 24ft sea ray that was costing us a fortune, ($400/mo just for dry storage), and the fuel cost was out of control, sometimes $300 bucks to fill up). After selling the boat we used charters, but that was $1000 bucks a day for 4 of us.
Once we got the Hobie TI’s all tweaked in and safe for offshore, we could get out to the reefs and back averaging around 10 mph wind or no wind, it didn’t matter. We got our outings down to about a buck a day in fuel for the twin hybrid outboards.
Figuring out all the little fixes to overcome the many design flaws and re-designing the boats to suit our needs was all part of it.
Would I do it all again, heck yea, we had an absolute blast with our Hobies.
FE
PostPosted: Sat Sep 11, 2021 3:30 am
I had a pretty big leak around the drive well on my 2010 PA 14, I got about ten to fifteen gallons in the hull in about 4 hours. I didn't notice for a while since I use a trolling motor, but it started wallowing and riding low, so I headed back in.
I fixed it with a can of clear (as seen on TV) Flex Seal, about ten bucks. Sprayed the drive well inside and out, and just for good measure sprayed in all the scupper holes and one crack on top side behind the seat. That was a couple of years ago, and it hasn't taken in any water since. If it starts leaking again I'll just get another can of flex seal.
Just to be safe though, I now tote along a manual bilge pump in my crate on all trips
PostPosted: Wed Jan 05, 2022 2:55 pm
FE
Happy New Year! I know this is an older thread, but it's an interesting discussion.
As I don't own a Hobie (though I hope to), I can't picture this exact "tang" that's creating the "extreme point load," but I do believe I follow your very detailed explanation of why it's causing the cracking. And I have a question:
I'm comfortable working with metal--would it be possible to grind/file or "Dremel" off 1/8" (or more?) of the leading edge of this "tang" so that it can't press forward enough to contact the front of the drive well? (And if I've got things turned around, please clarify, but in any event, I'm sure you understand what I'm suggesting, i.e., remove the pressure point, rather than spread the area the pressure is being applied to....) Thanks.
PostPosted: Wed Jan 05, 2022 8:15 pm
Greenwater:
I don’t advise shortening the tang.
Most of this thread is about way older boats.
Hobies current designs are rock solid and shouldn’t give you any issues, just use your boat when you get it, and most important, have fun.
PS they have the best warranty in the business, if anything happens they are always right on it, (thru the dealers).
FE
