It is currently Sun Jun 07, 2026 10:00 pm
 Post subject: Mast Rake
PostPosted: Wed Jul 18, 2018 9:28 am
I have searched, I have read the tuning tips.
I have 50" at the base of the mast halyard triangle with the boat level.
This translates to 11* of rake.
The shrouds are pinned in the bottom hole.
The head stay is pinned in the top hole on the furler.
The rig is just a touch loose.
Am I on the right track?
Thanks GH
 Post subject: Re: Mast Rake
PostPosted: Wed Jul 18, 2018 9:44 am
No answer for you but I am interested in what the experienced sailors say.
What is your weight?
I weigh 230 and I have been sailing my 14 turbo pinned on the bottom or 2nd holes on the shroud since I got mine.
Do you have the rotary furler? Mine only has the short cable from the mast and no adjustment so I am wondering if there is supposed to be any adjustment there?
84 14T Redline #67 Blue Hawaii faded but still working!
82 Yellow hull16 '81 Boomer nationals 20.9 on GPS
83 White hull 16 No sails "Clean and Purty Now!"
87 White hull no sails no tramp
PostPosted: Wed Jul 18, 2018 11:31 am
I'm about 200 lb. That's a bit heavy for a 14T. I do have a roller furling jib. It only has two pin holes on top of the furler drum. The bottom of the head stay only fits well in the top hole.
There is no adjustment at the top.
PostPosted: Wed Jul 18, 2018 4:58 pm
For your weight, that is about right. To tighten the rig a bit more, I suggest reversing the shroud adjusters. It should give you one more hole for tension. After a while, you could take new measurements and custom fit standing rigging.
Have fun!
Bob :wink:
Bob Curry
Master Unirig Sailor
PostPosted: Wed Jul 18, 2018 6:16 pm
Have fun!
Bob :wink:
Bob thanks for the reply,
Please elaborate on " reversing the shroud adjusters".
The single hole end is pinned to the chain plate on the tramp rail.
The shroud is pinned to the lowest hole on the ten hole side of the adjuster.
Thanks GH
PostPosted: Wed Jul 18, 2018 6:38 pm
Right, turn it upside down.
Bob Curry
PostPosted: Thu Jul 19, 2018 10:03 am
Brilliant!!! Thanks Bob! :D
1984 H16 "Mister Rogers"
1984 H14 "Sundays"
2000 H20 "Jet"
Sheet In, Max Out
PostPosted: Thu Jul 19, 2018 5:41 pm
That would close it up by about one hole but cause an ugly hang up spot.
My mast has an extra hound about 3" above the stock one.
I put an adjuster into the upper hound and pinned in only the forstay.
This kept a 10* rake and tightened up the rig just about right.
Thanks for all the replies. GH
