It is currently Sun Aug 02, 2026 12:31 pm
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
PostPosted: Fri Apr 13, 2007 3:00 pm
Penetrol? I'll have to look into that. I wonder if gun blueing agent would work?
--Tad
Tad Jones
1985 Hobie 18 - Redline
Magnum Wings
PostPosted: Sat Apr 14, 2007 12:57 am
While anodizing would be preferred, has anyone tried this product?
http://www.nyalic.com/
As far as powder coating, I've had numerous bad experiences with powder coated aluminum while living close to the salt air. The aluminum corrodes under the coating and finally the coating flakes off leaving a thick layer of aluminum oxide. This may not happen if the aluminum had been anodized first however.
TC
 Post subject: Re: Anodized Aluminum
PostPosted: Mon Mar 14, 2011 1:45 am
Hi all
I just solve crossbars and boom painting. I want use powder coating (in my country komaxit) with furnace burning of course on sanded surface. Is it good idea? I have good experience with this on steel parts. But I am not sure in case alu profiles...
Somewhere I read about base epoxide and polyuretane color on aluminium parts. Especially propeler.
thank you
PostPosted: Mon Mar 14, 2011 4:14 am
Powder coating does not work well on aluminum parts - it is heavy and chips.
Hobie Cat tried it with the "Formula" boats in the early '90s and stopped because of the problems with chipping.
PostPosted: Mon Mar 14, 2011 4:41 am
If it chipping, it look that alu parts are more elastic than komaxit powdered coat accept.
here is pic of front crossbar with scratches.
PostPosted: Mon Mar 14, 2011 10:55 am
On the quick, simple and cheap, I use a permanent black marker to darken small nicks and scrapes. It isn’t anything to fancy or lasting, but it is quick, cheap, and easy and does a decent job of temporary blemish cover-up. :wink:
PostPosted: Mon Mar 14, 2011 2:49 pm
Wood stove paint works good and has a long lasting finish.
Rich Vilvens
F-18 5150
