It is currently Fri Jul 03, 2026 8:04 pm
PostPosted: Wed Aug 01, 2018 6:24 am
MIRAGE DRIVE PROBLEM.
The stainless steel pin that hole the fins is riding out of place by 1/4 inch which keeps the pedals stuck in place when you need to pull them out. i used wiggling and force to pop it out. i tightened the screws at top of fin but the problem continued. i tap it back in place and its fine but coming in thru the surf so its a big problem. thank you
PostPosted: Wed Aug 01, 2018 10:41 am
What we would call the sprocket shaft? The screw you tightened is the allen set screw? Maybe not in a detent or the spine is cracked allowing the screw to come loose? Blue loc tite?
