It is currently Tue Aug 11, 2026 10:23 pm
 Post subject: Bungee loop use?
PostPosted: Sat Aug 11, 2018 5:15 pm
I have a new 2017 PA and it has a loop of bungee cord around 2" diameter attached under the rear edge of the mid floor hatch ( the one just in front of the seat). Is there a specific use for this. Is it to be used to hold the pedal back ( with another bungee) to keep the fins raised or is there some other reason it is there? Thanks
 Post subject: Re: Bungee loop use?
PostPosted: Mon Aug 13, 2018 8:04 pm
Does your owners manual give you a clue to what you found?
If it was a bungee to hold the mirage drive flat against the hull, the bungee would be on top of the deck and have a plastic retainer hook on the end.
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Thu Aug 16, 2018 1:39 pm
Mine has that also, but in the front, and it is not the bungee for holding the drive in the spread eagle position. Can't find anything about it in the owners manual.
PostPosted: Fri Aug 17, 2018 10:17 am
if you're referring to the small little one at the front of the square hatch, that is where you slide the directional cables under, helps keep tension on them
PostPosted: Fri Aug 17, 2018 4:30 pm
Yes, keeps the shifters centered and down out of the way. You can do it either way.
