It is currently Fri Apr 03, 2026 9:53 am
PostPosted: Wed Jul 18, 2018 2:22 pm
I got a mirage classic for a really good deal but doesn’t have rudder or mirage drive installed. In fact, it doesn’t even have holes for the lines for the rudder. What parts do I need and what should I know about it before I start trying. What size of hole do I drill or is it easier I take it to a hobie dealer to get them drilled?
PostPosted: Wed Jul 18, 2018 3:02 pm
Confused?? Does it have a hole for the drive?
PostPosted: Wed Jul 18, 2018 3:23 pm
What you have is likely what we called an "Aspire". That is a project! There are a LOT of parts required to make it a functioning Mirage kayak.
A MirageDrive runs $622 for the GT standard Fin version.
Rudder parts can be found in the parts diagrams here: https://cdn.hobiecat.com/digital_assets/International_Kayak_August_2018.pdf#page=60
Instructions here: https://static.hobiecat.com/digital_assets/80018.pdf
Not all of parts are available in that vintage, but here is a list of what was in a kit back then... nearly 20 years ago.
80005 XXMIRAGE UPGRADE KIT: MIRAGE DRV MECHANISMXX
& COMPLETE STEERING KIT W/RUDDER
2103 1.000 EA 0.000% SHOCK CORD MOUNT
2104 1.000 EA 0.000% ADJ SHOCK CORD HOOK 3/8"
80014 1.000 EA 0.000% TAG MIRAGE DRIVE
8031150 1.000 EA 0.000% SCREW #10 x 1/2 PHSMS-P
8012000 1.000 EA 0.000% RIVET ALUM BULB-TYPE
8004810 1.330 LF 0.000% SHOCKCORD 1/4" BLACK
Steering
81370 1.000 EA 0.000% XXSTEERING CRANK (pre 2011)XX
8080690 3.000 EA 0.000% WASHER 3/8x3/4 NYLON-FLAT (ABA
81012 1.000 EA 0.000% XXSTEERING HANDLE-BLKXX
8010180 2.000 EA 0.000% RIVET POP 3/16x1/4 PH-SS (ABA)
53170020 1.000 EA 0.000% SCREW 1/4-20 X 1/2 SKTST (ABA)
Rudder up/down control
81380 1.000 EA 0.000% CONTROL ARM - UP/DOWN
81375 1.000 EA 0.000% COMPRESSION SPRING (1)
8080690 1.000 EA 0.000% WASHER 3/8x3/4 NYLON-FLAT (ABA
81032 1.000 EA 0.000% RUDDER UP/DOWN HNDL-MFG
Control lines
81400 14.333 LF 0.000% TUBING HI-DENSITY PE
8010130 4.000 EA 0.000% RIVET POP 3/16x3/8 PH-SS
DELETE 8004830; CHANGE 81023, 53180010;
ADD 8004810: ECO #04-0221.
CHANGE 81400, 81023: ECO #04-0241.
81023 22.333 LF 0.000% LINE-CONTROL 700 lb GRAY
8063000 5.000 EA 0.000% SLEEVE NICROPRESS 1/16
8004810 1.333 LF 0.000% SHOCKCORD 1/4" BLACK
81390 1.000 EA 0.000% RUDDER MIRAGE (disc)
8003510 0.375 LF 0.000% DELRIN ROD .375 D X 5' BLACK
20860010 2.000 EA 0.000% LARGE KEY RING
8030170 2.000 EA 0.000% SCREW 12-24 x 3/4 RHMS-P
8080540 2.000 EA 0.000% WASHER 1/4 X 5/8 FLAT SS (ABA)
Steering Line Separator
71110 1.000 EA 0.000% PAD EYE-BLK NYLON-3/8"
8030280 1.000 EA 0.000% SCREW 10-32x3/4 RHMS-P SS
8050200 1.000 EA 0.000% NUT #10-32 HEX NYLOCK
Tools
53170022 1.000 EA 0.000% HEX KEY 1/8"
80215 1.000 EA 0.000% DRILL BIT.3860 "W LETTER" - MI
80115 1.000 EA 0.000% DRILL BIT 7/32"
Hydrosail Mech.
80010 STD 1.000 EA 0.000% MIRAGE DRIVE-STD/PRODUCTION
PostPosted: Thu Aug 23, 2018 8:00 pm
I stopped reading that parts list before my head exploded. I think I’ll just paddle it or put a MirageDrive in and steer it with my paddle. I found a fully functioning mirage classic a few months back and probably should have snapped it up and used my current one as a backup but should’a, would’a, coulda.
