It is currently Fri Aug 07, 2026 12:47 am
PostPosted: Wed Aug 29, 2018 6:54 am
Hello,
Could you please tell me what are the biggest differences between 2011 and 2018 Hobie Adventure Island.
Thanks very much
Best regards
Jercec
PostPosted: Wed Aug 29, 2018 10:53 am
As I remember, the 2011 vs 2015, the '11 dives much more ('15 has larger bow), the '15 has a larger sail/mast. The '11 has a bucket seat...you literally sit in water (living in South Florida, I never minded that). The '15 has the new Vantage seat. The '15 has the same separation of the aka bars as the tandem; the '11 does not. Presumably the '18 will have the new aka/cross bar connectors. There are probably other things, but I believe those are the big items.
The 2015, and presumably the 2018, is a better sailing boat than the 2011. Still, I liked my 2011.
PostPosted: Thu Aug 30, 2018 2:23 am
apart the new hull as mentioned before and the seat that were introduced in 2015, the 2011 model had a system to lock the seats that was not very efficient. you should have pegs that, in my 2012 AI never worked properly. since 2013 the pegs have a different and better locking mechanism. I think u can easily upgrade it. another difference is in the scupper holes that are weaker thereore i suggest you not to use that kind of dolly cart cause somebody damaged the hull with it.
