It is currently Sun Jun 07, 2026 3:32 pm
 Post subject: Seat not seating
PostPosted: Wed Sep 05, 2018 11:26 am
I have been using my IA for about 3 months now. I love it. I am having on issue getting the seat to attach to the bar (sorry, don't know the right name). I usually end up screwing with it for about 5 minutes most times to get it attached maybe half the time. The other times I go out, i just give up and it is just resting on the bar. What is the key here?
Gerry
 Post subject: Re: Seat not seating
PostPosted: Wed Sep 05, 2018 11:39 am
Place the seat in the hull. Place your hand around the bar and seat base. Lift the rear of the seat until the front locks in. Lower the rear again and clip the strap to hold. Super easy with the right technique.
At the 2:30 mark: https://youtu.be/-uLvP_XparU?t=150
PostPosted: Wed Sep 05, 2018 1:21 pm
Yeah I have seen this video and do this, still don't have much luck. It's not super easy on my boat.
PostPosted: Wed Sep 05, 2018 2:12 pm
Raise the front bar up - if that bar is in the lowest setting it makes it trickier.
Jacques Bernier
http://www.hobie.com/
PostPosted: Fri Sep 07, 2018 5:06 am
I will take a look. I didn't realize the bar was adjustable.
Gerry
PostPosted: Tue Oct 16, 2018 7:24 am
I've got the same problem. I put the seat on the bar, raise the back, squeeze bar and when I rotate it down the front rubs on the hull and pops it out of position. Raising the bar helps but doesn't make it easy. I'd love to have the seat higher all the time but anytime you lean forward the back legs folds up and the resulting seating angle is terrible. So if you raise it to get the seat locked in you then have to lower it or fight the legs. It's all workable just a P.I.T.A.
I've got both seats locked in and I haven't removed then since.
