It is currently Sat Jul 04, 2026 4:29 am
 Post subject: Livewell Problems
PostPosted: Wed Sep 26, 2018 1:41 pm
Just recently bought a second hand Livewell V1. When I bought it, it was working no problem but when I got it home and tested it at home it no longer worked. Battery is charged and brand new and has 6v coming out of it. I wasn’t getting any readings on the multimeter with the switch turned on and off. Took apart the female connector on the tank where it connects the the battery, took another reading with battery plugged in and was only getting 4v on the female side of the plugs. Will have to replace the entire wiring harness for this? Kinda unfortunate that it would work fine one second and then not work at all.
 Post subject: Re: Livewell Problems
PostPosted: Wed Sep 26, 2018 6:38 pm
Search live well issues....I recall there was a problem with the sealed switch assembly and it needed to be replaced.
Dr.SteelheadCatcher
Warrenton, OR
