It is currently Wed Jun 25, 2025 10:04 am
PostPosted: Tue Sep 11, 2018 3:35 pm
I just wanted to share my installation for anyone wanting to do this.
https://kayakfishingutah.wixsite.com/mysite/blog/hobie-pro-angler-steering-upgrade
-Chad
PostPosted: Wed Sep 26, 2018 12:29 pm
Interesting, still waiting to get my used 2012 PA14 wet. Wonder if Hobie incorporated this in their latest model?
Thank you,
Roy Niswanger
PostPosted: Wed Sep 26, 2018 6:53 pm
I installed the rudder BOA in my 2013 PA-14 several years ago too. It really takes the "slop" out of the twin tillers.......you will find the BOA will need to be snugged up when the hull is cold, but loosened up when it becomes warmer....the hull expands a tad and places extra, unnecessary internal tension on all of the hardware unless you loosen the BOA.
Lastly, I always relax the BOA tension once I have loaded my PA on the trailer and drop the rudder as there is no need to place any strain on the internal pulley blocks/sheaves.
The BOA was made standard in the 2014 model year PA-14
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Tue Dec 18, 2018 8:21 am
Hello again Dr.SteelheadCatcher!
It has become painfully obvious I need this tensioner installed on my 2012 PA 14 and so I have decided to but the kit. But, could you please proof KayakFishingUtah's link on install instructions? Seems step 2 contradicts step 4 diagram showing the tensioner knob on the STBD side but step 2 says to drill the hole for it on the PORT side?
https://kayakfishingutah.wixsite.com/my ... ng-upgrade
He also mentions a rudder upgrade. I need to find which one. I have the stock currently. I also have a sail kit that I will use on this PA and a Revo 13 2009 model. I did buy the sailing rudder for the 2009 Revo 13. It's the stow and go flip up version. I assume the PA upgrade rudder is different? I have yet to search this, just wanted to ask.
Thank you,
Thank you,
Roy Niswanger
PostPosted: Tue Dec 18, 2018 8:42 am
Hi Roy,
The BOA is mounted on the port side.....what I can't confirm is if your 2012 PA rudder is rigged exactly the same as the 2013.
On the earlier PA's, Hobie had the rudder/tiller handle mounted on the seat frame and that was not an optional solution. They did eventually change it, but I don't remember what year it was implemented.
Matt can confirm if your 2012 PA rudder layout is the same as 2013's.
When I installed my BOA, it was before information was available, so I visited my local Hobie dealer and checked out a new 2014 PA, to see how and where it was installed.
I installed the "rudder upgrade" to improve tracking while I down rig fish....it's about 25% larger and helped....the down side is you no longer can raise the bow while the stern is on the ground....the rudder extends beyond the cavity that it's retracted into.
Good luck!
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Tue Dec 18, 2018 10:00 am
Thanks, so this image from KayakFisherUtah is incorrect?
Here's my PA14...look close, my steering handle has a raised knob I made from SS threaded bar and an old router handle knob:
Hi Roy,
Good luck!
Thank you,
Roy Niswanger
PostPosted: Tue Dec 18, 2018 9:08 pm
Roy, the 2013 PA has dual steering, so I think the 2012 is different, based on your photo....????
You can look inside to see if the line routing is like the diagram and if it is, then adding the BOA on the port side should work.
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Wed Dec 19, 2018 6:28 am
Yep! 2012 PA14 only had the single rudder control on the left side. No need for the BOA on that model year. :wink:
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Unfair Lures Pro Staff
Ziptailz Ambassador
2015 Pro Angler 14 - Papaya
2018 Compass - Sea Grass
PostPosted: Wed Dec 19, 2018 6:34 am
No I don't have dual steering, so I guess this is a bunk idea now? I've tightened the control lines best I can and still this this is super sloppy, I'm always having to make adjustments. No other options here for tighter lines?
Thank you,
Roy Niswanger
PostPosted: Tue Mar 10, 2020 4:55 am
Hello,
Does anyone have an installation video of this? The ones posted no longer work.
I bought the BOA and block to install on my 2019 Hobie Outback which suffers from the loose line issue similar as I understand to the Pro Angler.
Thanks for any help for this.
