It is currently Tue Aug 04, 2026 3:11 pm
 Post subject: Oasis seat Issue
PostPosted: Sat Mar 30, 2019 9:46 am
I have a 2015 Oasis. the front seat back support is often crooked. The left side seems to lock in to a desired upright position. The right side will often drop down a notch when pressure is applied to the backrest. Both seats function fine in the rear seating location. Both seats do not function properly in the front seat location. And unfortunately, that is where the "Queen" sits. Suggestions?
I have been given the advice before to make sure the seat pivot point screw is tight. I check it every time but it does not fix the issue.
 Post subject: Re: Oasis seat Issue
PostPosted: Sat Mar 30, 2019 4:50 pm
Sounds weird. Will it happen if Her Majesty sits in the back?
PostPosted: Thu Apr 04, 2019 4:17 am
She has never sat in the back. I have sat in the front. It only does it in the front seat location. I have noticed that in order to put the seat in the highest position with the little supports extended, the supports are too long to fit into the seat well and has to be slightly manipulated to drop into the well. This would indicate that perhaps the seat bar was installed too far back.
PostPosted: Thu Apr 04, 2019 5:13 am
So you're saying it's catching where I have indicated?
PostPosted: Tue Apr 09, 2019 5:23 am
YES
PostPosted: Tue Apr 30, 2019 5:32 am
Nothing?
Crickets?
No one has had this issue?
PostPosted: Tue Apr 30, 2019 9:21 am
How about lowering the front all the way... than attempting to deploy the aft pegs. May give it extra length to work with?
