It is currently Thu Aug 20, 2026 4:23 pm
PostPosted: Tue Apr 23, 2019 7:59 pm
I bought a Hook-proof Map Pocket to install on my new Compass. I have seen the Hobie video on how to do this. However, the pocket does not come with mounting screws. What specific screws should I use?
PostPosted: Thu Apr 25, 2019 5:02 am
I've never had one of these in my hand. I just recently ordered one and it's on it's way to me but looking at the photo it looks like these will work https://www.amazon.com/Stainless-Phillips-Screw-Bolt-Dropper/dp/B079YBQW9J/ref=sr_1_2_sspa?keywords=%238+bugle+head+stainless+screw&qid=1556193785&s=industrial&sr=1-2-spons&psc=1
You want a tapered or cone shaped head so they will countersink into the pre-drilled holes in the map pocket. 1" in length should be plenty. Of course watch for rudder cables or things behind where you plan on drilling. I like to use my phone and run it into the hull while in video mode so I can see what's back there before I drill.
PostPosted: Thu Apr 25, 2019 8:42 am
The pocket with frame comes with screws. Did you order a replacement pocket maybe?
78565001 MAP POCKET MOLDED MESH W/FRAME US$ 15.99
There are two screws in the frame holding it together and 4 additional screws...
8031501 SCREW 8 X 3/4" FHSMS-P SS
These are great! I have one on my garage wall to tuck my kayak hoist lines into. I also added two in the back walls of the bed of my Tacoma to tuck tie down lines into.
PostPosted: Fri Apr 26, 2019 7:14 am
I just received one yesterday I ordered from Mariner Sails and it did not have screws either.
Correction it looks like pan head screws will work better after looking at it.
Here's what I plan on buying for installing my map pocket
https://www.amazon.com/Stainless-Phillips-Screws-Bolt-Dropper/dp/B075DHD8JV?ref_=fsclp_pl_dp_5
Mark if you wouldn't mind confirming this that would be awesome!
PostPosted: Fri Apr 26, 2019 8:25 am
The holes in the frame are counter sunk. If you only got a replacement pocket (rubber mesh not the hard plastic frame)... pan head would work, but the edges of the pocket would not be uniformly held down.
